Hello to you.
I have a VitalPbx in version 3.2.3.6
I have a problem with a Trunk Sip. The Trunk provider tells me that my Trunk Sip registers in UDP protocol. He would like me to register in TCP protocol.
Where do we make this change.
You find that in “device profiles”.
And then the profile in trunk.
For pjsip you can choose udp / tcp and so on as transport right in trunk.
Unrelated. This is end of life. Consider updating.
Thanks for the answer. In the profile TCP and UDP are selected. Is there a way to know which of the two is used (even under SSH)
For the version I think I will upgrade it.
That means that it is up to the remote party to decide what protocol to use. You can select just TCP to force the remote party to use this protocol only.
thanks for the reply
