Trunk Registration
I’m just getting started with VitalPBX, but I’m having trouble registering a trunk. Could you please help me identify what I might be missing or doing wrong? I’ve been following the Udemy VitalPBX lessons step by step, and I did everything exactly as shown in the video. I’ve also included my system information and a screenshot of the trunk registration. Thank you in advance!
You don’t need a Local Secret if the authentication is outbound.
Some other recommendations:
  • Empty the Contacts field. This is created automatically; it is only needed when you have multiple IP addresses or domains for outbound calls.
  • Select the option IP in the field Identify By.
  • Select the Default PJSIP Profile in the field Profile.
  • Set a valid Trunk CID. Most providers required a valid outbound CID to place calls.
  • Set the parameter Overwrite CID to If not provided.
It is registered now. Thank you!
But the problem is when I try to check and call this number. It says it’s not registered(In our language.) Do you have any idea about it? I did inbound route too.
Screenshot 2025-09-19 at 11.37.16
