Troubleshoot Voicemail Transcriptions
We randomly see that Voicemail Transcriptions aren’t working.
It just shows:
--- Voicemail Transcription ---
But nothing is below that.
I see that in /etc/asterisk/vitalpbx/voicemail__10-general.conf that it uses /usr/share/vitalpbx/scripts/voicemail2email to process the emails, but that file is encrypted.
Are these transcription or mail attempts logged anywhere?
Since last update we have reports of the same issue.
We were not made aware that the update would break the current Voicemail transcription setup that was manually set up months ago.
When looking at the release notes of the latest update (4.1.0-8) we see that the API with OpenAI only applies to Carrier Plus and VitalPBX One subscriptions.
We luckily have the Carrier Plus but we dont see the API Key settings in Voicemail Settings.
This is causing issues with all our tenants for a feature they are paying for and would like assistance for a quick resolution.
Follow these steps.
Configure Voicemail Transcription with OpenAI
We have followed these steps, the problem is that it is randomly not working.
The code is prepared to send an error message attached to the voicemail if the transcription cannot be performed!
Hello, we also noticed the same random issue with voicemail transcription.
We dont see an error message. The voicemail audio is very clear and should not be an issue.
Below is an example of a working transcription follow by a missing one.
Please advise
Another voicemail was left and we got a transcription this time.
Weirdly, some text was added at the end that was not at all part of the voice message at all.
The part highlighted.
Translated, this added part says “Closed Captioning by the French Canadian Broadcasting Company”.
That is so weird!
Did this improve for you in the latest update?
We have found that half of our transcriptions are now in Welsh rather than English which is quite exciting.
Try updating and report back.
We are on the latest version now which has highlighted the issue.
We just released a new update for the AI Assistants add-on. You can update it from the add-ons module on VitalPBX.
The new update allows configuring the input language and temperature for the voicemail transcription.
You can set up both in the AI Tools module.
Did this update help you?
Hi All,
Just to let you know the latest version of the AI Assistants has fixed all our issues. You can now set a language and temperature (we like 0.2) and it seems to be working great.
