Currently running: 3.0.9-5
This PBX was upgraded from version 2. Now, when running yum update, it gives me this error -
(I also uploaded the below to pastebin for easier read: https://pastebin.com/raw/7FjKrEyp)
[root@vitalpbx ~]# yum update
Loaded plugins: fastestmirror
Determining fastest mirrors
epel/x86_64/metalink | 13 kB 00:00:00
* base: mirror.atlanticmetro.net
* epel: mirror.siena.edu
* extras: centos.mirror.constant.com
* updates: mirror.siena.edu
asterisk-mirror-sounds | 2.9 kB 00:00:00
asterisk-sounds | 2.9 kB 00:00:00
base | 3.6 kB 00:00:00
epel | 4.7 kB 00:00:00
extras | 2.9 kB 00:00:00
mariadb | 3.4 kB 00:00:00
sonata-suite | 2.9 kB 00:00:00
sonata-suite-mirror | 2.9 kB 00:00:00
updates | 2.9 kB 00:00:00
http://repo.vitalpbx.org/devel/rpms/x86_64/repodata/repomd.xml: [Errno 14] HTTP Error 404 - Not Found
Trying other mirror.
To address this issue please refer to the below wiki article
https://wiki.centos.org/yum-errors
If above article doesn't help to resolve this issue please use https://bugs.centos.org/.
One of the configured repositories failed (VitalPBX Repo),
and yum doesn't have enough cached data to continue. At this point the only
safe thing yum can do is fail. There are a few ways to work "fix" this:
1. Contact the upstream for the repository and get them to fix the problem.
2. Reconfigure the baseurl/etc. for the repository, to point to a working
upstream. This is most often useful if you are using a newer
distribution release than is supported by the repository (and the
packages for the previous distribution release still work).
3. Run the command with the repository temporarily disabled
yum --disablerepo=vitalpbx_devel ...
4. Disable the repository permanently, so yum won't use it by default. Yum
will then just ignore the repository until you permanently enable it
again or use --enablerepo for temporary usage:
yum-config-manager --disable vitalpbx_devel
or
subscription-manager repos --disable=vitalpbx_devel
5. Configure the failing repository to be skipped, if it is unavailable.
Note that yum will try to contact the repo. when it runs most commands,
so will have to try and fail each time (and thus. yum will be be much
slower). If it is a very temporary problem though, this is often a nice
compromise:
yum-config-manager --save --setopt=vitalpbx_devel.skip_if_unavailable=true
failure: repodata/repomd.xml from vitalpbx_devel: [Errno 256] No more mirrors to try.
Here’s the repolist:
[root@vitalpbx ~]# yum repolist
Loading mirror speeds from cached hostfile
asterisk-mirror-sounds/x86_64/primary_db | 5.3 kB 00:00:00
asterisk-sounds/x86_64/primary_db | 5.3 kB 00:00:00
base/7/x86_64/primary_db | 6.1 MB 00:00:00
epel/x86_64/primary_db | 6.9 MB 00:00:00
extras/7/x86_64/primary_db | 242 kB 00:00:00
mariadb/primary_db | 61 kB 00:00:00
sonata-suite/x86_64/primary_db | 34 kB 00:00:00
sonata-suite-mirror/x86_64/primary_db | 34 kB 00:00:00
updates/7/x86_64/primary_db | 9.6 MB 00:00:01
vpbx-base/x86_64 | 2.9 kB 00:00:00
vpbx-base/x86_64/primary_db | 277 kB 00:00:00
vpbx-base-mirror/x86_64 | 2.9 kB 00:00:00
vpbx-base-mirror/x86_64/primary_db | 277 kB 00:00:00
vpbx-core/x86_64 | 2.9 kB 00:00:00
vpbx-core/x86_64/primary_db | 86 kB 00:00:00
vpbx-core-mirror/x86_64 | 2.9 kB 00:00:00
vpbx-core-mirror/x86_64/primary_db | 86 kB 00:00:00
vpbx-extras/x86_64 | 2.9 kB 00:00:00
vpbx-extras/x86_64/primary_db | 41 kB 00:00:00
vpbx-extras-mirror/x86_64 | 2.9 kB 00:00:00
vpbx-extras-mirror/x86_64/primary_db | 41 kB 00:00:00
repo id repo name status
asterisk-mirror-sounds/x86_64 Asterisk Sounds Mirror 19
asterisk-sounds/x86_64 Asterisk Sounds 19
base/7/x86_64 CentOS-7 - Base 10,072
epel/x86_64 Extra Packages for Enterprise Linux 7 - x86_64 13,638
extras/7/x86_64 CentOS-7 - Extras 498
mariadb MariaDB 100
sonata-suite/x86_64 Sonata Suite 45
sonata-suite-mirror/x86_64 Sonata Suite Mirror 45
updates/7/x86_64 CentOS-7 - Updates 2,579
vitalpbx_devel/x86_64 VitalPBX Repo 0
vpbx-base/x86_64 VitalPBX Base 586
vpbx-base-mirror/x86_64 VitalPBX Base Mirror 586
vpbx-core/x86_64 VitalPBX Core 132
vpbx-core-mirror/x86_64 VitalPBX Updates Mirror 132
vpbx-extras/x86_64 VitalPBX Extras 138
vpbx-extras-mirror/x86_64 VitalPBX Extras Mirror 138
repolist: 28,727
[root@vitalpbx ~]# ll /etc/yum.repos.d/
total 60
-rw-r--r-- 1 root root 1664 Nov 23 2020 CentOS-Base.repo
-rw-r--r-- 1 root root 1309 Nov 23 2020 CentOS-CR.repo
-rw-r--r-- 1 root root 649 Nov 23 2020 CentOS-Debuginfo.repo
-rw-r--r-- 1 root root 314 Nov 23 2020 CentOS-fasttrack.repo
-rw-r--r-- 1 root root 630 Nov 23 2020 CentOS-Media.repo
-rw-r--r-- 1 root root 1331 Nov 23 2020 CentOS-Sources.repo
-rw-r--r-- 1 root root 8515 Nov 23 2020 CentOS-Vault.repo
-rw-r--r-- 1 root root 616 Nov 23 2020 CentOS-x86_64-kernel.repo
-rw-r--r-- 1 root root 1050 Oct 31 2020 epel.repo
-rw-r--r-- 1 root root 1149 Oct 31 2020 epel-testing.repo
-rw-r--r-- 1 root root 154 Dec 1 2020 mariadb.repo
-rw-r--r-- 1 root root 1512 Jun 20 01:31 vitalpbx.repo
-rw-r--r-- 1 root root 113 Apr 20 2020 vpbx_devel.repo
