I’m having trouble installing V4 using the vpbx4-0-1-amd64-netinst.iso posted on the blog.
Upon running install_vitalpbx4, the installation gets blocked with missing packages.
Package php-mysqlnd is a virtual package provided by:
php8.1-mysql 8.1.10-1+0~20220914.25+debian11~1.gbp7fe5a8
php7.4-mysql 7.4.30-1+deb11u1
You should explicitly select one to install.
Package php-pdo is a virtual package provided by:
php8.1-common 8.1.10-1+0~20220914.25+debian11~1.gbp7fe5a8
php7.4-common 7.4.30-1+deb11u1
E: Package 'php-pdo' has no installation candidate
E: Package 'php-mysqlnd' has no installation candidate
If I use the script debian_vpbx_installer.sh used to install V4 on Raspberry pie and set the missing package to php7.4-pdo and php7.4-mysqlnd or php8.1-pdo and php8.1-mysqlnd, the installation can proceed but it ends with this error message
PHP Fatal error: The file /usr/share/vitalpbx/scripts/apply_migrations encoded as type [1/74] cannot be decoded by this version of the ionCube Loader.
in Unknown on line 0
chown: cannot access '/var/lib/vitalpbx/static': No such file or directory
dpkg: error processing package vitalpbx (--configure):
installed vitalpbx package post-installation script subprocess returned error exit status 1
Can anyone please confirm if they got similar issues and recommend a way how to fix it. thanks in advance
