Here are logs showing line calling IN…
2022-11-15 15:29:02] VERBOSE[11409][C-00019276] pbx.c: Executing [14078894128@T7_default-trunk:2] Gosub(“SIP/BVSIn4-00031a25”, “sub-check-blacklist,s,1(8c722eb3d2a7c453,4074019259)”) in new stack [2022-11-15 15:29:02] VERBOSE[11409][C-00019276] pbx.c: Executing [s@sub-check-blacklist:1] NoOp(“SIP/BVSIn4-00031a25”, “Testing if 4074019259 is in Black List”) in new stack [2022-11-15 15:29:02] VERBOSE[11409][C-00019276] pbx.c: Executing [14078894128@T7_default-trunk:3] Gosub(“SIP/BVSIn4-00031a25”, “sub-stir-shaken-verify,s,1(8c722eb3d2a7c453,4074019259)”) in new stack [2022-11-15 15:29:02] VERBOSE[11409][C-00019276] pbx.c: Executing [14078894128@T7_default-trunk:5] Gosub(“SIP/BVSIn4-00031a25”, “dynamic-routing-in,s,1(4074019259)”) in new stack [2022-11-15 15:29:02] VERBOSE[11409][C-00019276] pbx.c: Executing [s@dynamic-routing-in:2] Set(“SIP/BVSIn4-00031a25”, “EXTERNAL_CALLER=4074019259”) in new stack [2022-11-15 15:29:02] VERBOSE[11409][C-00019276] pbx.c: Executing [14078894128@T7_incoming-calls:5] Gosub(“SIP/BVSIn4-00031a25”, “sub-set-call-vars,s-incoming,1(4074019259,14078894128,8c722eb3d2a7c453)”) in new stack [2022-11-15 15:29:02] VERBOSE[11409][C-00019276] pbx.c: Executing [s-incoming@sub-set-call-vars:3] Set(“SIP/BVSIn4-00031a25”, “__INCOMING_SOURCE=4074019259”) in new stack [2022-11-15 15:29:02] VERBOSE[11409][C-00019276] pbx.c: Executing [s-incoming@sub-set-call-vars:6] Set(“SIP/BVSIn4-00031a25”, “__CALL_SOURCE=4074019259”) in new stack [2022-11-15 15:29:02] VERBOSE[11409][C-00019276] pbx.c: Executing [s-incoming@sub-set-call-vars:7] Set(“SIP/BVSIn4-00031a25”, “__CS=4074019259”) in new stack [2022-11-15 15:29:02] VERBOSE[11409][C-00019276] pbx.c: Executing [app-incoming@sub-set-call-vars:3] Set(“SIP/BVSIn4-00031a25”, “CDR(source)=4074019259”) in new stack [2022-11-15 15:29:08] VERBOSE[11409][C-00019276] pbx.c: Executing [4@IVR-25:2] System(“SIP/BVSIn4-00031a25”, “/usr/share/vitalpbx/scripts/ivr_stats “25” “4” “PROSOURCE TECH” “4074019259” “14078894128” “1668544142.568060"”) in new stack [2022-11-15 15:29:08] VERBOSE[11409][C-00019276] pbx.c: Executing [app-incoming@sub-set-call-vars:3] Set(“SIP/BVSIn4-00031a25”, “CDR(source)=4074019259”) in new stack [2022-11-15 15:29:08] VERBOSE[11433][C-00019276] pbx.c: Executing [s@T7_cos-all:2] NoOp(“Local/110@T7_ring-group-dial-0001076b;2”, “Dialing 110 from 4074019259”) in new stack [2022-11-15 15:29:08] VERBOSE[11433][C-00019276] pbx.c: Executing [s@sub-construct-cid:2] Set(“Local/110@T7_ring-group-dial-0001076b;2”, “CALL_SOURCE=4074019259") in new stack [2022-11-15 15:29:08] VERBOSE[11433][C-00019276] pbx.c: Executing [s@sub-construct-cid:3] Set(“Local/110@T7_ring-group-dial-0001076b;2”, “CS=4074019259") in new stack [2022-11-15 15:29:08] VERBOSE[11433][C-00019276] pbx.c: Executing [s-local@sub-get-device-tree:1] NoOp(“Local/110@T7_ring-group-dial-0001076b;2”, “Try to determianate caller technology 4074019259”) in new stack [2022-11-15 15:29:08] VERBOSE[11433][C-00019276] pbx.c: Executing [s@sub-construct-cid:12] Set(“Local/110@T7_ring-group-dial-0001076b;2”, “CDR(source)=4074019259”) in new stack [2022-11-15 15:29:08] VERBOSE[11433][C-00019276] pbx.c: Executing [110@sub-local-dialing:9] Set(“Local/110@T7_ring-group-dial-0001076b;2”, “DB(8c722eb3d2a7c453/LASTCALLER/110)=4074019259”) in new stack [2022-11-15 15:29:08] VERBOSE[11433][C-00019276] pbx.c: Executing [110@sub-local-dialing:36] Set(“Local/110@T7_ring-group-dial-0001076b;2”, “DIAL_OPTIONS=ktrb(before-connecting-call^s^1(8c722eb3d2a7c453^4074019259^110^^))”) in new stack [2022-11-15 15:29:08] VERBOSE[11433][C-00019276] pbx.c: Executing [110@sub-local-dialing:37] Set(“Local/110@T7_ring-group-dial-0001076b;2”, “DIAL_OPTIONS=ktrb(before-connecting-call^s^1(8c722eb3d2a7c453^4074019259^110^^))U(sub-call-recording^8c722eb3d2a7c453^4074019259^110^no)”) in new stack [2022-11-15 15:29:08] VERBOSE[11433][C-00019276] pbx.c: Executing [110@sub-local-dialing:50] Dial(“Local/110@T7_ring-group-dial-0001076b;2”, “SIP/fsfl110,30,ktrb(before-connecting-call^s^1(8c722eb3d2a7c453^4074019259^110^^))U(sub-call-recording^8c722eb3d2a7c453^4074019259^110^no)”) in new stack [2022-11-15 15:29:08] VERBOSE[11433][C-00019276] app_stack.c: SIP/fsfl110-00031a27 Internal Gosub(before-connecting-call,s,1(8c722eb3d2a7c453,4074019259,110,)) start [2022-11-15 15:29:08] VERBOSE[11433][C-00019276] pbx.c: Executing [s@before-connecting-call:3] Set(“SIP/fsfl110-00031a27”, “CALLER=4074019259”) in new stack [2022-11-15 15:29:08] VERBOSE[11433][C-00019276] app_stack.c: SIP/fsfl110-00031a27 Internal Gosub(before-connecting-call,s,1(8c722eb3d2a7c453,4074019259,110,)) complete GOSUB_RETVAL= [2022-11-15 15:29:14] VERBOSE[11433][C-00019276] app_stack.c: SIP/fsfl110-00031a27 Internal Gosub(sub-call-recording,s,1(8c722eb3d2a7c453,4074019259,110,no)) start [2022-11-15 15:29:14] VERBOSE[11433][C-00019276] pbx.c: Executing [s@sub-call-recording:4] Set(“SIP/fsfl110-00031a27”, “CALLER=4074019259”) in new stack [2022-11-15 15:29:14] VERBOSE[11433][C-00019276] app_stack.c: SIP/fsfl110-00031a27 Internal Gosub(sub-call-recording,s,1(8c722eb3d2a7c453,4074019259,110,no)) complete GOSUB_RETVAL= [2022-11-15 15:29:42] VERBOSE[11608][C-0001927b] pbx.c: Executing [s@sub-check-diversions:2] Set(“Local/110@T7_ring-group-dial-0001076b;2”, "OLD_CALLER_ID="SAT:PROSOURCE TECH” <4074019259>") in new stack [2022-11-15 15:29:42] VERBOSE[11608][C-0001927b] pbx.c: Executing [s@sub-check-diversions:8] Set(“Local/110@T7_ring-group-dial-0001076b;2”, "CALLERID(all)="SAT:PROSOURCE TECH” <4074019259>”) in new stack
PL
Paul Lenic
11/15/2022 3:30 PM
[2022-11-15 15:29:36] VERBOSE[11608][C-0001927b] pbx.c: Executing [101@sub-local-dialing:8] Set(“SIP/fsfl110-00031a2d”, “DIAL_STRING=SIP/fsfl101”) in new stack [2022-11-15 15:29:36] VERBOSE[11608][C-0001927b] pbx.c: Executing [s@parse-dial-string:1] NoOp(“SIP/fsfl110-00031a2d”, “Parsing dial string: SIP/fsfl101”) in new stack [2022-11-15 15:29:36] VERBOSE[11608][C-0001927b] pbx.c: Executing [s@parse-dial-string:4] Set(“SIP/fsfl110-00031a2d”, “CURRENT_DEVICE=SIP/fsfl101”) in new stack [2022-11-15 15:29:36] VERBOSE[11608][C-0001927b] pbx.c: Executing [s@parse-dial-string:7] Set(“SIP/fsfl110-00031a2d”, “USER=fsfl101”) in new stack [2022-11-15 15:29:36] VERBOSE[11608][C-0001927b] pbx.c: Executing [s@parse-dial-string:15] Set(“SIP/fsfl110-00031a2d”, “PARSED_DEV=SIP/fsfl101”) in new stack [2022-11-15 15:29:36] VERBOSE[11608][C-0001927b] pbx.c: Executing [s@parse-dial-string:17] Set(“SIP/fsfl110-00031a2d”, “NEW_DIAL_STRING=SIP/fsfl101”) in new stack [2022-11-15 15:29:36] VERBOSE[11608][C-0001927b] pbx.c: Executing [s@parse-dial-string:24] NoOp(“SIP/fsfl110-00031a2d”, “New dialstring: SIP/fsfl101”) in new stack [2022-11-15 15:29:36] VERBOSE[11608][C-0001927b] pbx.c: Executing [s@parse-dial-string:25] Set(“SIP/fsfl110-00031a2d”, “DIAL_STRING=SIP/fsfl101”) in new stack [2022-11-15 15:29:36] VERBOSE[11608][C-0001927b] pbx.c: Executing [101@sub-local-dialing:50] Dial(“SIP/fsfl110-00031a2d”, “SIP/fsfl101,30,ktrb(before-connecting-call^s^1(8c722eb3d2a7c453^110^101^^))U(sub-call-recording^8c722eb3d2a7c453^110^101^no)”) in new stack [2022-11-15 15:29:36] VERBOSE[11608][C-0001927b] app_stack.c: SIP/fsfl101-00031a2e Internal Gosub(before-connecting-call,s,1(8c722eb3d2a7c453,110,101,)) start [2022-11-15 15:29:36] VERBOSE[11608][C-0001927b] pbx.c: Executing [s@before-connecting-call:1] NoOp(“SIP/fsfl101-00031a2e”, “Executing routines in the newly created channel before initiaing the call”) in new stack [2022-11-15 15:29:36] VERBOSE[11608][C-0001927b] pbx.c: Executing [s@before-connecting-call:2] Set(“SIP/fsfl101-00031a2e”, “TENANT=8c722eb3d2a7c453”) in new stack [2022-11-15 15:29:36] VERBOSE[11608][C-0001927b] pbx.c: Executing [s@before-connecting-call:3] Set(“SIP/fsfl101-00031a2e”, “CALLER=110”) in new stack [2022-11-15 15:29:36] VERBOSE[11608][C-0001927b] pbx.c: Executing [s@before-connecting-call:4] Set(“SIP/fsfl101-00031a2e”, “CALLEE=101”) in new stack [2022-11-15 15:29:36] VERBOSE[11608][C-0001927b] pbx.c: Executing [s@before-connecting-call:5] Set(“SIP/fsfl101-00031a2e”, “EXEC_AA=”) in new stack [2022-11-15 15:29:36] VERBOSE[11608][C-0001927b] pbx.c: Executing [s@before-connecting-call:6] Set(“SIP/fsfl101-00031a2e”, “CUSTOM_ALERT_INFO=”) in new stack [2022-11-15 15:29:36] VERBOSE[11608][C-0001927b] pbx.c: Executing [s@before-connecting-call:7] Set(“SIP/fsfl101-00031a2e”, “APP_TYPE=NONE”) in new stack [2022-11-15 15:29:36] VERBOSE[11608][C-0001927b] pbx.c: Executing [s@before-connecting-call:8] GosubIf(“SIP/fsfl101-00031a2e”, “0?sub-auto-answer,s,1”) in new stack [2022-11-15 15:29:36] VERBOSE[11608][C-0001927b] pbx.c: Executing [s@before-connecting-call:9] GosubIf(“SIP/fsfl101-00031a2e”, “0?sub-set-custom-header,s,1(Alert-Info,)”) in new stack [2022-11-15 15:29:36] VERBOSE[11608][C-0001927b] pbx.c: Executing [s@before-connecting-call:10] GosubIf(“SIP/fsfl101-00031a2e”, “0?sub-set-custom-header,s,1(Call-Info,)”) in new stack [2022-11-15 15:29:36] VERBOSE[11608][C-0001927b] pbx.c: Executing [s@before-connecting-call:11] Gosub(“SIP/fsfl101-00031a2e”, “sub-set-custom-header,s,1(CALL-TYPE,LOCAL)”) in new stack [2022-11-15 15:29:36] VERBOSE[11608][C-0001927b] pbx.c: Executing [s@sub-set-custom-header:1] NoOp(“SIP/fsfl101-00031a2e”, “Setting up custom header”) in new stack [2022-11-15 15:29:36] VERBOSE[11608][C-0001927b] pbx.c: Executing [s@sub-set-custom-header:2] GotoIf(“SIP/fsfl101-00031a2e”, “1?set-sip”) in new stack [2022-11-15 15:29:36] VERBOSE[11608][C-0001927b] pbx.c: Executing [s@sub-set-custom-header:6] NoOp(“SIP/fsfl101-00031a2e”, “Add SIP Headers”) in new stack [2022-11-15 15:29:36] VERBOSE[11608][C-0001927b] pbx.c: Executing [s@sub-set-custom-header:7] SIPAddHeader(“SIP/fsfl101-00031a2e”, “CALL-TYPE: LOCAL”) in new stack [2022-11-15 15:29:36] VERBOSE[11608][C-0001927b] pbx.c: Executing [s@sub-set-custom-header:8] Return(“SIP/fsfl101-00031a2e”, “”) in new stack [2022-11-15 15:29:36] VERBOSE[11608][C-0001927b] pbx.c: Executing [s@before-connecting-call:12] Gosub(“SIP/fsfl101-00031a2e”, “sub-set-custom-header,s,1(APPLICATION,NONE)”) in new stack [2022-11-15 15:29:36] VERBOSE[11608][C-0001927b] pbx.c: Executing [s@sub-set-custom-header:1] NoOp(“SIP/fsfl101-00031a2e”, “Setting up custom header”) in new stack [2022-11-15 15:29:36] VERBOSE[11608][C-0001927b] pbx.c: Executing [s@sub-set-custom-header:2] GotoIf(“SIP/fsfl101-00031a2e”, “1?set-sip”) in new stack [2022-11-15 15:29:36] VERBOSE[11608][C-0001927b] pbx.c: Executing [s@sub-set-custom-header:6] NoOp(“SIP/fsfl101-00031a2e”, “Add SIP Headers”) in new stack [2022-11-15 15:29:36] VERBOSE[11608][C-0001927b] pbx.c: Executing [s@sub-set-custom-header:7] SIPAddHeader(“SIP/fsfl101-00031a2e”, “APPLICATION: NONE”) in new stack [2022-11-15 15:29:36] VERBOSE[11608][C-0001927b] pbx.c: Executing [s@sub-set-custom-header:8] Return(“SIP/fsfl101-00031a2e”, “”) in new stack [2022-11-15 15:29:36] VERBOSE[11608][C-0001927b] pbx.c: Executing [s@before-connecting-call:13] GosubIf(“SIP/fsfl101-00031a2e”, “0?sub-set-custom-header,s,1(QUEUE-NAME,)”) in new stack [2022-11-15 15:29:36] VERBOSE[11608][C-0001927b] pbx.c: Executing [s@before-connecting-call:14] GosubIf(“SIP/fsfl101-00031a2e”, “0?T7_before-connecting-call-hook,s,1”) in new stack [2022-11-15 15:29:36] VERBOSE[11608][C-0001927b] pbx.c: Executing [s@before-connecting-call:15] Return(“SIP/fsfl101-00031a2e”, “”) in new stack [2022-11-15 15:29:36] VERBOSE[11608][C-0001927b] app_stack.c: Spawn extension (T7_cos-all, 101, 1) exited non-zero on ‘SIP/fsfl101-00031a2e’ [2022-11-15 15:29:36] VERBOSE[11608][C-0001927b] app_stack.c: SIP/fsfl101-00031a2e Internal Gosub(before-connecting-call,s,1(8c722eb3d2a7c453,110,101,)) complete GOSUB_RETVAL= [2022-11-15 15:29:36] VERBOSE[11608][C-0001927b] app_dial.c: Called SIP/fsfl101
