Is there a way top seamlessly while on a call transfer or switch a device? example, I’m using a polycom / grandstream deskphone and need to move to my cell either with webrtc or the vitalpbx app without the caller noticing it?
thanks
thanks
The described behavior isn’t supported by Asterisk.
Fast 3 way call and then A will just hang up?
Thanks, vey good option,
