Suggestion to Sonata Dealer (If possible)
Hi Vitalpbx Teams,
  • You can create a schedule rule for the campaign, for example : If disposition > negative, max attempt : 10 times
  • Can create new lists from finished lists, for example
    Initially on list A there were 100 customer lists and after finishing only 50 were connected (positive). From the report, a new list can be created by filtering the (negative) ones and then reassigning them to the same campaign or to another campaign.
  • The form is created dynamically in the “option field”, for example if option A is selected, then there are sub options from A, A1, A2, A3
And an upload documents will be great.
