Hi.
I have 5 tenants im my vitalpbx (main + 4).
In sonata suite recordings, I get a database error (it happens just in two of the tenants).
That error appears while choosing menu options (in many of them). For example, menu->settings->users or menu->reports->filters.
It makes impossible to access any recordings.
The error is:
select teams.team_id as team_id,teams.description as description,teams.flag_profile_id as flag_profile_id,teams.default as default,teams.tenant_id as tenant_id from telerec.rec_teams as teams where team_id in ()SQLSTATE[42000]: Syntax error or access violation: 1064 You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near ‘)’ at line 1
Can you help me.
