Hi Vitalpbx Team,
Why is the start time not correct?
At 12:34 I have logged out of vitxi webrtc page then login then “login to queue”
It should be next record “start_time” > 12:34 but it appears at 12:30
Is this a bug?
Hi Vitalpbx,
Any update about start_hour?
We’ll proceed to do some tests and let you know what we find, also make sure you have set the report settings
Do you see the same result on any of the other session reports?
please execute the following commands and share the results for analysis
In the current implementation the records are ordered by agent and queue not by time, times are corret according to that data
Hi Sir,
May be easy to see report if you sort by agent, queue and time.
Thank you for the suggestion we’ll consider adding filters for ordering results for a future update
Thanks @Roger & All vitalpbx team.
