We have VitalPBX 4.0.0. R7 with the lastest version of SONATA STATS already installed and set up. After updating to the latest version Sonata Stats gave us the setup screen. During the update process I did see some message in which was mentioning the SONATA STATS, but could capture any screenshots. This would be in the logs, right? Which ones can I provide
Now since the SONATA Stats is giving the set up screen asking the for root password, even typing the correct one does not help, it says that failed to established connection. I like I mention we have SONATA Stats set up.
This happened to me in to different systems, one just updated only the SONATA Stats add-on and the second time just now updating 4.0.0 R7 to 4.0.0 R8
I have another system that I need to update R7 to R8 and it SONATA STATS installed and set up with users , permissions, agents sync, and see what happened.
For the moment the current system in my office after doing the command,
rm -f /var/lib/sonata/stats/wizard.conf
I click on the SONATA Stats option on vitalpbx
click next on the database settings
click next on the PBX Settings
and this is what happened after click next on the reporting settings
If you need to check the logs let me know which ones you need.
