SONATA DIALER - 404 Not Found
Dear,
I’m using VitalPBX 4.5 and have access to all SONATAS, but except for SONATA DIALER, I don’t have access. I try to access it and get the error below.
404 Not Found
nginx/1.22.1
Thank you for your support in helping me resolve this issue.
Regards
Same here, could someone shed some light on this ?
(having vitalPBX 4.5 )
Do a full system update to fix it!
apt clean all
apt update
apt upgrade -y
Or update the Dialer from the VitalPBX add-ons module.
Dear,
I tried updating the module via add-ons, but it didn’t work.
I’m using the latest version of VitalPBX Carrier Plus 4.5.1-2 — PBX Engine 20.15.0-1
Remove the add-on and then install from scratch!
Dear Miguel.^
Problem is solved.
1st: command: sudo apt-get --purge remove sonata-dialer -y
E: dpkg was interrupted, you must manually run ‘sudo dpkg --configure -a’ to correct the problem.
2nd: Commad: root@vitalpbx:~# sudo dpkg --configure -a
after 2nd command process, I was able to access Sonata Dialer.
