I’im using Sonata Billing
When i generate a detailed report, i see my individual calls being calculated but at the total field it is 0!
Capture d’écran 2021-09-09 à 22.04.16|690x20
how can i get the total field populated. Thanks
Hello @ZAIO,
What version of the Sonata Billing are you using?
Could you share the settings that you are using in the report builder module?
Hey,
Could you share a screenshot of your Display Settings from the Company Profile module?
Thanks for the info.
We will run some tests with those parameters.
I’ll keep you posted.
Hello Miguel
Any info on the tests.
Arye
Hey @ZAIO,
We will release an update to fix this issue soon.
It’s out, @ZAIO!
Thanks VPBX team, it works!
