Hello Team,
There is a documentation how to setup a sip trunk with a Gateway Cisco ?
Need help please
Hello Team,
Need help please
It is important that you indicate which Gateway model you want to register. Usually we have never had a problem registering FXS gateways. Remember to always update the firmware of those devices. We stay tuned. Best regards.
Hello, is not a fxs gateway it’s a cisco router finally the trunk is up, external call working but the problem is on the inbound rules
Ok, PJSIP or SIP?
Then you have a Cisco Router registered with the VitalPBX, It is for a PSTN service through any of the VWICs in the Cisco Router, are you using the Cisco Router as a Gateway with the PSTN?
If the answer is affirmative, which interface do you use with them, PRI-ISDN-T1, PRI-ISDN-E1, BRI, DTI, FXO, or SIP Trunk?
Or are you using the Cisco Router and VWIC for FXS?
Best regards!
VitalPBX with SIP trunk to Cisco 2800 router - VitalPBX Community Hi, check this related topic, also this: GOIP GSM GATEWAY - VitalPBX Community and this: Hello I need to configure a tronkal with a Grandstream HT813 gateway - VitalPBX Community
