I am new to Vitalpbx and I am trying to test it out.I have an ip based sip trunk with only outbound calls working.On inbound calls I am getting a 401 unauthorized error to the invite.I have whitelisted the provider’s ip address and I am using the default routing method.
On the log file viewer I am getting No matching endpoint found Failed to authenticate.
Share your trunk configs and hide any sensitive info!
Pjsip need to have trunk Identify to either authenticate or accept the connection
Add in trunk
Identify by : IP
Match : 34.203.130.151
Hi Mohamed
I have identify by ip and Match provider ip set but I am still getting 401 Unauthorized to the invite.
Just to let you know I got incoming calls working.I put the provider ip in the Match Header box instead of in the Match box.
Thanks for all your help.
Mark the answer as correct please
Does the IP address go in the “Match” field or the “Match Header” field?
Add ip address in MATCH Field and Match by IP
Thanks for clarifying.
