Hey folks, I have been trying to get SIPS and SRTP setup with the provider Telnyx.
I have gotten most of the way there I believe but asterisk constantly complains it cant setup the call because it does not trust the certificate from Telnyx.
Error below:
[2025-08-12 10:29:38] ERROR[829338][C-00000005]: res_rtp_asterisk.c:3348 __rtp_recvfrom: DTLS failure occurred on RTP instance '0x7f514xxxxxxxxx' due to reason 'certificate verify failed', terminating
When I run a open_ssl check to verify the certificate is trusted by the system I get a OK(0) response:
openssl s_client -connect sip.telnyx.com:5061 -servername sip.telnyx.com -CApath /etc/ssl/certs </dev/null | tail -n 2
depth=2 C = US, ST = New Jersey, L = Jersey City, O = The USERTRUST Network, CN = USERTrust RSA Certification Authority
verify return:1
depth=1 C = GB, ST = Greater Manchester, L = Salford, O = Sectigo Limited, CN = Sectigo RSA Domain Validation Secure Server CA
verify return:1
depth=0 CN = sip.telnyx.com
verify return:1
DONE
Verify return code: 0 (ok)
This is my transport settings:
sudo asterisk -rx 'pjsip show transport transport-tls-608c7bb6130ab9815fbe'
Transport: <TransportId........> <Type> <cos> <tos> <BindAddress....................>
Transport: transport-tls-608c7bb6130ab9815fbe tls 0 0 0.0.0.0:5061
ParameterName : ParameterValue
allow_reload : true
allow_wildcard_certs : No
async_operations : 1
bind : 0.0.0.0:5061
ca_list_file :
ca_list_path : /etc/ssl/certs
cert_file : /usr/share/vitalpbx/certificates/vitalpbx-lab.xxxxxx.com/bundle.pem
cipher :
cos : 0
domain :
external_media_address : 5xxxxxx
external_signaling_address : 5xxxxxx
external_signaling_port : 5061
local_net : 10.0.0.0/255.0.0.0
local_net : 172.16.0.0/255.240.0.0
method : tlsv1_2
ms_signaling_address :
password :
priv_key_file : /usr/share/vitalpbx/certificates/vitalpbx-lab.xxxx.com/private.pem
protocol : tls
require_client_cert : No
symmetric_transport : false
tcp_keepalive_enable : false
tcp_keepalive_idle_time : 30
tcp_keepalive_interval_time : 1
tcp_keepalive_probe_count : 5
tos : 0
verify_client : No
verify_server : Yes
websocket_write_timeout : 100
I also had to add the parameter “ca_list_path” to the transport for it to use the CA trusted cert. This did not seem to be an option in the gui to add this. Maybe something necessary for future releases?
Just wondering if anyone is able to assist with this. Thank you!
Blockquote
