SIP Registration 404 Not Found
SIP Registration failed and got ‘404 Not Found’ code when SIP Account login to Yealink DECT W52P|W56P. But when SIP Account login with soft-phone (Zoiper), SIP Registration is Success.
Call Flow
                                 Call flow for [email protected] (Color by Request/Response)
        │REGISTER sip:10.17.28.11:5060 SIP/2.0
         10.17.28.7:5060               10.17.28.11:5060             │Via: SIP/2.0/UDP 10.17.28.7:5060;branch=z9hG4bK727295058;rport
      ──────────┬─────────          ──────────┬─────────            │From: "Extension Name" <sip:[email protected]:5060>;tag=2478142817
                │          REGISTER           │                     │To: "Extension Name" <sip:[email protected]:5060>
07:00:49.382522 │ ──────────────────────────> │ │Call-ID: [email protected]
+0.000724 │ 404 Not Found │ │CSeq: 1 REGISTER
07:00:49.383246 │ <────────────────────────── │ │Contact: sip:[email protected]:5060
│ │ │Allow: INVITE, INFO, PRACK, ACK, BYE, CANCEL, OPTIONS, NOTIFY, REGISTER
│ │ │SUBSCRIBE, REFER, PUBLISH, UPDATE, MESSAGE
│ │ │Max-Forwards: 70
│ │ │User-Agent: Yealink W52P 25.81.0.60
│ │ │Expires: 3600
│ │ │Allow-Events: talk,hold,conference,refer,check-sync
│ │ │Line: 5
│ │ │Content-Length: 0
        │SIP/2.0 404 Not Found
         10.17.28.7:5060               10.17.28.11:5060             │Via: SIP/2.0/UDP 10.17.28.7:5060;rport=5060;received=10.17.28.7;branch=
      ──────────┬─────────          ──────────┬─────────            │hG4bK727295058
                │          REGISTER           │                     │Call-ID: [email protected]
07:00:49.382522 │ ──────────────────────────> │ │From: “Extension Name” sip:[email protected];tag=2478142817
+0.000724 │ 404 Not Found │ │To: “Extension Name” sip:[email protected];tag=z9hG4bK727295058
07:00:49.383246 │ <────────────────────────── │ │CSeq: 1 REGISTER
│ │ │Server: VitalPBX
To: “Extension Name” sip:[email protected]:5060
CSeq: 1 REGISTER
Allow: INVITE, INFO, PRACK, ACK, BYE, CANCEL, OPTIONS, NOTIFY, REGISTER, SUBSCRIBE, REFER, PUBLISH, UPDATE, MESSAGE
Max-Forwards: 70
Expires: 3600
Line: 5
Content-Length: 0
2022/10/29 07:00:49.383246 10.17.28.11:5060 → 10.17.28.7:5060
Via: SIP/2.0/UDP 10.17.28.7:5060;rport=5060;received=10.17.28.7;branch=z9hG4bK727295058
CSeq: 1 REGISTER
Server: VitalPBX
Content-Length: 0
Hi @Htun_Min_Myat and welcome to the forums.
Assuming you are using PJSIP, please enabled debug, redo the registration attempt, post the output to pastebin.com and share the link here.
(Enable debug: pjsip set logger on)
Hi @PitzKey and thanks for your reply.
Now, the problem is solved when I changed the IP address in the Match Section of the Trunk Setting. Because I assigned IP Address with the Subnet in the Match Section of the Trunk Setting.
LOG:
res_pjsip_registrar.c: AOR ‘’ not found for endpoint ‘sip-trunk-user’
Please provide a screenshot from your Trunk config
https://drive.google.com/file/d/1JCgIc8WgYGR6d0DUC75BBvwhO55xaKTB/view?usp=share_link
https://drive.google.com/file/d/1BvNqHF_8J10Cr5yIwGqh4m1qO4hqSPHr/view?usp=share_link
Here it is hyphens, in your screenshot it is underscores between the words.
I have w52P and password length was the issue. Not over 7 characters worked for me.
