-- Goto (sub-setup-callrec-name,s,11)
-- Executing [s@sub-setup-callrec-name:11] Return("PJSIP/100-00000002", "") in new stack
-- Executing [12488418561@trk-1-dial:39] Dial("PJSIP/100-00000002", "PJSIP/12488418561@v27500,90,kKtrU(sub-before-bridging-call^8eedaf332be054ed^100^12488418561^no)") in new stack
<--- Transmitting SIP request (909 bytes) to UDP:192.76.120.10:5060 --->
INVITE sip:[email protected]:5060 SIP/2.0
Via: SIP/2.0/UDP 152.44.42.168:5060;rport;branch=z9hG4bKPjb72b27ed-4a7e-4dcf-a358-04adf87d2235
From: <sip:[email protected]>;tag=f51b9274-5647-42fa-ab0f-d924b9b11f91
To: <sip:[email protected]>
Contact: <sip:[email protected]:5060>
Call-ID: d8f9331a-5401-4b41-9f23-d124c0f33488
CSeq: 9046 INVITE
Allow: OPTIONS, REGISTER, SUBSCRIBE, NOTIFY, PUBLISH, INVITE, ACK, BYE, CANCEL, UPDATE, PRACK, MESSAGE, REFER
Supported: 100rel, timer, replaces, norefersub, histinfo
Session-Expires: 1800
Min-SE: 90
Max-Forwards: 70
User-Agent: VitalPBX
Content-Type: application/sdp
Content-Length: 239
v=0
o=- 1986624609 1986624609 IN IP4 152.44.42.168
s=Asterisk
c=IN IP4 152.44.42.168
t=0 0
m=audio 12062 RTP/AVP 0 101
a=rtpmap:0 PCMU/8000
a=fmtp:101 0-16
a=ptime:20
a=maxptime:150
a=sendrecv
-- Called PJSIP/12488418561@v27500
<--- Transmitting SIP response (492 bytes) to UDP:97.70.106.84:1036 --->
SIP/2.0 180 Ringing
Via: SIP/2.0/UDP 192.168.1.16:5060;rport=1036;received=97.70.106.84;branch=z9hG4bK2738780104
Call-ID: [email protected]
From: "Ontral-100" <sip:[email protected]>;tag=2927482117
To: <sip:[email protected]>;tag=ba2e3815-7b6a-4789-8245-f67063db3fe5
CSeq: 2 INVITE
Server: VitalPBX
Contact: <sip:152.44.42.168:5060>
Content-Length: 0
<--- Received SIP response (378 bytes) from UDP:192.76.120.10:5060 --->
SIP/2.0 100 Telnyx Trying
Via: SIP/2.0/UDP 152.44.42.168:5060;rport=5060;branch=z9hG4bKPjb72b27ed-4a7e-4dcf-a358-04adf87d2235;received=152.44.42.168
CSeq: 9046 INVITE
Server: Telnyx SIP Proxy
Content-Length: 0
<--- Received SIP response (735 bytes) from UDP:192.76.120.10:5060 --->
SIP/2.0 407 Proxy Authentication Required
Via: SIP/2.0/UDP 152.44.42.168:5060;received=152.44.42.168;rport=5060;branch=z9hG4bKPjb72b27ed-4a7e-4dcf-a358-04adf87d2235
To: <sip:[email protected]>;tag=vXv1Hv3tSN1va
CSeq: 9046 INVITE
Accept: application/sdp
Allow: INVITE, ACK, BYE, CANCEL, OPTIONS, MESSAGE, INFO, UPDATE, REFER, NOTIFY
Supported: path
Allow-Events: talk, hold, conference, refer
Proxy-Authenticate: Digest realm="sip.telnyx.com", nonce="5c5200ff-2259-4259-82ea-6964c9e3f9af", algorithm=MD5, qop="auth", opaque="9cc6aa58-c549-485c-af4e-0875bff7c1b4/10.13.36.4"
Content-Length: 0
<--- Transmitting SIP request (402 bytes) to UDP:192.76.120.10:5060 --->
ACK sip:[email protected]:5060 SIP/2.0
CSeq: 9046 ACK
Max-Forwards: 70
Content-Length: 0
<--- Transmitting SIP request (1253 bytes) to UDP:192.76.120.10:5060 --->
Via: SIP/2.0/UDP 152.44.42.168:5060;rport;branch=z9hG4bKPj814dea79-4685-406e-b4db-813dfd0e579f
CSeq: 9047 INVITE
Min-SE: 90
Max-Forwards: 70
Proxy-Authorization: Digest username="v27500", realm="sip.telnyx.com", nonce="5c5200ff-2259-4259-82ea-6964c9e3f9af", uri="sip:[email protected]:5060", response="d818274f8c3039f1303572fcc034cea2", algorithm=MD5, cnonce="082f8b7fa5484f5e8f1e4fab605cf32f", opaque="9cc6aa58-c549-485c-af4e-0875bff7c1b4/10.13.36.4", qop=auth, nc=00000001
Content-Length: 239
v=0
s=Asterisk
t=0 0
a=fmtp:101 0-16
a=ptime:20
a=maxptime:150
a=sendrecv
Via: SIP/2.0/UDP 152.44.42.168:5060;rport=5060;branch=z9hG4bKPj814dea79-4685-406e-b4db-813dfd0e579f;received=152.44.42.168
CSeq: 9047 INVITE
Content-Length: 0
<--- Received SIP response (627 bytes) from UDP:192.76.120.10:5060 --->
SIP/2.0 403 Caller Origination Number is Invalid D35
Via: SIP/2.0/UDP 152.44.42.168:5060;received=152.44.42.168;rport=5060;branch=z9hG4bKPj814dea79-4685-406e-b4db-813dfd0e579f
Max-Forwards: 69
To: <sip:[email protected]>;tag=X6NtKQmypyQFp
CSeq: 9047 INVITE
Supported: path
Reason: Q.850;cause=21;text="CALL_REJECTED"
Content-Length: 0
CSeq: 9047 ACK
Max-Forwards: 70
Content-Length: 0
== Everyone is busy/congested at this time (1:0/0/1)
-- Executing [12488418561@trk-1-dial:40] GotoIf("PJSIP/100-00000002", "0?:after-fax") in new stack
-- Goto (trk-1-dial,12488418561,43)
-- Executing [12488418561@trk-1-dial:43] NoOp("PJSIP/100-00000002", "End Fax Section") in new stack
-- Executing [12488418561@trk-1-dial:44] NoOp("PJSIP/100-00000002", "After Dial") in new stack
-- Executing [12488418561@trk-1-dial:45] GotoIf("PJSIP/100-00000002", "1?come-back") in new stack
-- Goto (trk-1-dial,12488418561,47)
-- Executing [12488418561@trk-1-dial:47] Return("PJSIP/100-00000002", "") in new stack
-- Executing [12488418561@trk-1:3] GotoIf("PJSIP/100-00000002", "1?come-back") in new stack
-- Goto (trk-1,12488418561,5)
-- Executing [12488418561@trk-1:5] Return("PJSIP/100-00000002", "") in new stack
-- Executing [s-1@cos-all-post:4] NoOp("PJSIP/100-00000002", "Hangup Cause: 21, Dial Status: CHANUNAVAIL") in new stack
-- Executing [s-1@cos-all-post:5] ForkCDR("PJSIP/100-00000002", "e") in new stack
-- Executing [s-1@cos-all-post:6] GotoIf("PJSIP/100-00000002", "0?end_call") in new stack
-- Executing [s-1@cos-all-post:7] GosubIf("PJSIP/100-00000002", "0?sub-outbound-queue-call,s,1") in new stack
-- Executing [s-1@cos-all-post:8] GotoIf("PJSIP/100-00000002", "1?app-termination,busy,1") in new stack
-- Goto (app-termination,busy,1)
-- Executing [busy@app-termination:1] NoOp("PJSIP/100-00000002", "Termination: Signal the other end that the line is busy") in new stack
-- Executing [busy@app-termination:2] NoCDR("PJSIP/100-00000002", "") in new stack
-- Executing [busy@app-termination:3] Progress("PJSIP/100-00000002", "") in new stack
-- Executing [busy@app-termination:4] PlayTones("PJSIP/100-00000002", "busy") in new stack
-- Executing [busy@app-termination:5] Wait("PJSIP/100-00000002", "2") in new stack
> 0x7f590428dc10 -- Strict RTP learning after remote address set to: 192.168.1.16:12278
<--- Transmitting SIP response (835 bytes) to UDP:97.70.106.84:1036 --->
SIP/2.0 183 Session Progress
CSeq: 2 INVITE
Server: VitalPBX
Content-Length: 300
v=0
o=- 20018 20020 IN IP4 152.44.42.168
s=Asterisk
t=0 0
m=audio 15302 RTP/AVP 0 8 18 101
a=rtpmap:8 PCMA/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=fmtp:101 0-16
a=ptime:20
a=maxptime:150
a=sendrecv
> 0x7f590428dc10 -- Strict RTP qualifying stream type: audio
> 0x7f590428dc10 -- Strict RTP switching source address to 97.70.106.84:12278
-- Executing [busy@app-termination:6] Busy("PJSIP/100-00000002", "10") in new stack
<--- Transmitting SIP response (483 bytes) to UDP:97.70.106.84:1036 --->
SIP/2.0 486 Busy Here
CSeq: 2 INVITE
Server: VitalPBX
Content-Length: 0
== Spawn extension (app-termination, busy, 6) exited non-zero on 'PJSIP/100-00000002'
<--- Received SIP request (319 bytes) from UDP:97.70.106.84:1036 --->
Via: SIP/2.0/UDP 192.168.1.16:5060;branch=z9hG4bK2738780104
CSeq: 2 ACK
Content-Length: 0
<--- Transmitting SIP request (408 bytes) to UDP:97.70.106.84:1036 --->
OPTIONS sip:[email protected]:1036 SIP/2.0
Via: SIP/2.0/UDP 152.44.42.168:5060;rport;branch=z9hG4bKPj7893af49-2203-44ae-841e-9178585eea64
From: <sip:[email protected]>;tag=8541cd95-69ab-4bc9-b28f-d7887ada4d9f
Call-ID: 4fa9ddb0-5544-4f97-a8ed-3efaa9ad7cfa
CSeq: 45842 OPTIONS
Max-Forwards: 70
Content-Length: 0
<--- Received SIP response (361 bytes) from UDP:97.70.106.84:1036 --->
SIP/2.0 200 OK
Via: SIP/2.0/UDP 152.44.42.168:5060;rport=5060;branch=z9hG4bKPj7893af49-2203-44ae-841e-9178585eea64
To: <sip:[email protected]>;tag=944809362
CSeq: 45842 OPTIONS
User-Agent: Yealink SIP-T29G 46.82.0.30
Content-Length: 0
<--- Transmitting SIP request (423 bytes) to UDP:192.76.120.10:5060 --->
OPTIONS sip:[email protected]:5060 SIP/2.0
Via: SIP/2.0/UDP 152.44.42.168:5060;rport;branch=z9hG4bKPj524c0710-d3f4-45cc-a2e9-ef3856cd0d60
From: <sip:[email protected]>;tag=9794b9ee-180f-4aea-8c19-cca4dc20179b
Call-ID: efa03bfd-eeec-4a57-a03a-9acfe286f617
CSeq: 618 OPTIONS
Max-Forwards: 70
Content-Length: 0
<--- Received SIP response (419 bytes) from UDP:192.76.120.10:5060 --->
SIP/2.0 200 Keepalive P20
Via: SIP/2.0/UDP 152.44.42.168:5060;rport=5060;branch=z9hG4bKPj524c0710-d3f4-45cc-a2e9-ef3856cd0d60;received=152.44.42.168
To: <sip:[email protected]>;tag=dfb4940bfc7117e4d7fa62ed6ef36d37.160d5670
CSeq: 618 OPTIONS
Content-Length: 0
