I would like to request an improvement in the input search in contacts by name.
If I have tow contacts with the same first name: AAA and search by “AAA” this will show me all the contacts started by AAA.
When I search by "AAA " plus a space, the result of search will not show me the last list.
We would like that the search could be done by the join of booth names (first name + last name) with filds concatenated in the search.
maynor
2
Hello Sir!
Thank you very much for your suggestion,
We will improve the input.
Regards!
maynor
4
Contact search has been improved, you can update VitXi!
VitXi Changelog: VitXi | VitalPBX Phone System | Change Log
Does this feature only work in VitalPBX 4?
We update VitXi to 1.1.2-4 in VitalPBX 3.2.3-8, and the search didn’t works:
After add one space:
By the way, after trying to import contacts, we received this error:
maynor
6
Please try reloading the application with CTRL + F5 or try in incognito mode,
maynor
7
Please try adding a column called “avatar” to your .csv. You can set this column with empty values.
After rebooting the computer it works:
