I have successfuly installed VitalPBX v4 on my VPS but I am unsure of the script to use as well as details such as the port number for reverese proxy configuration. I have already pointed A record of the subdomain I created to the IP of the VPS. Kindly help me with a step by step guide on how to do this. Thanks
Due to this is a custom implementation, you should google all the information about what you want to implement.
You can also use ChatGPT if you need quick answers about what you are looking for!
Does it mean you don’t need to do reverse proxy configuration, you just access the VitalPbx right from it’s IP
VitalPBX 4 uses Apache2. And no, we don’t use a reverse proxy to access the VitalPBX GUI.
I didn’t know reverse proxy is not needed. Thanks
