Restrict Access VitalPBX Admin, Sonata Suites and Vitxi
Hi Guys,
Is there a way to restrict access on Sonata Suites, Vitxi and etc (443 ports)
If I allow 443 on specific IP address it means that the user can access all those using 443 ports, like the following. Assuming on user1 I just want to give access only on Vitxi. I want to implement least privilege principle for better security wherein the user can access only what he/ she authorize to access. Yes, it has a login but it should also not accessible to user. Also, the login right now for Vitxi and Sonata Suites doesn’t have yet 2FA wherein its a great opportunity for the intruders to do brute force login.
[server-domain - administration
[server-domain]/webrtc/ - Vitxi
[server-domain]/recordings/
[server-domain]/stats
No, using different port per app isn’t possible!
How about editing the .conf files in apache2 sites-enabled?
Instead of Require all granted change to Require ip x.x.x.x?
You can try it!
Keep in mind that your changes will get overwritten on every package update!
