Is there a way to restore a fax that was mistakenly deleted from the Virtual Fax Viewer? I’ve made a quick search of the fax folder with WinSCP, but without knowing the filename it is a little hard to tell what is what.
No! The delete action deletes the database row and the file associated with it.
Perhaps that product feature update request then? A recycling bin would be a nice touch.
We don’t provide Soft-Deletes. As far as I remember, every delete option has a confirmation in case someone accidentally presses the delete option.
