Using multi-tenant module, we will certainly have customers which will create users and so on. However, the reload button on the top right can be confusing for the customer.
Is there a way, using a linux command or whatever to apply those pending changes somehow ?
root@pbx2:~# vitalpbx help gen-conf
gen-conf
It generate the Asterisk cnfigurations and re-build Asterisk DB for the main tenant only
root@pbx2:~# vitalpbx help fully-gen-conf
fully-gen-conf
It generates the Asteirsk configurations and re-build Asterisk DB for all the tenants
Thanks! However, even after doing those commands, the “reload” button is still showing up on the GUI, can the user dismiss this and the settings are still saved ?
