Good morning, I was trying to install VitalPBX 4 on a Raspberry PI, following this guide: https://vitalpbx.com/blog/install-vitalpbx-4-on-a-raspberry-pi-quick-guide/ . But for some reason I receive a SHA error, when it tried to download some of the files. Do you recently updates those files? Thanks with any help.
Same here many errors like this.
E: Failed to fetch http://repo.vitalpbx.org/vitalpbx/apt/base/pool/b/base/vitalpbx-asterisk-config_4.0.0-1_all.deb File has unexpected size (40352 != 40168). Mirror sync in progress? [IP: 107.150.37.66 80]
Hashes of expected file:
- SHA256:418fe0b303956730b419cf0acb5b1c7510a3a34e25b37646a32d488ddd9e211e
- SHA1:20522cf7cc323868ecaa12ad861c6c81c9657f77 [weak]
- MD5Sum:e2a04a63e630d68c9cc2d9dc94104f05 [weak]
- Filesize:40168 [weak]
Blockquote
Yes, that’s is the same kind of error that I have.
yes, same problem here…
The repo is now updated!!
PI does not update to 4.0.0.2
Try this and report back:
We will update PI later
The update for the PI version is now available.
apt update
apt upgrade
Hello, I have a problem installing VPX on Raspberry 3b+
Error follows;
- Installing MariaDB, apache2 and php 8 *
Reading package lists… Done
Building dependency tree… Done
Reading state information… Done
Package php8.1-fpm is not available, but is referred to by another package.
This may mean that the package is missing, has been obsolete, or
is only available from another source
Package php-ioncube-loader is not available, but is referred to by another package.
E: Package ‘php8.1-fpm’ has no installation candidate
E: Package ‘php-ioncube-loader’ has no installation candidate
Pi / arm is End Of Life.
