I recently bumped in to 2 issue in the Sonata switchboard
1.) When logging in a dynamic member to a queue (using the Queues widget) it will always use the {exten}@{hint_context} as the hint, even if the queue is set to ring unavailable agent where it should have used Agent{exten}@{hint_context}.
2.) The search bar in the Extensions widget doesn’t work when the widget is set to console mode
Thank you.
