I have an issue with queues, when Queue Callback is enabled, and I have an IVR set on the queue the IVR will not work.
Running:
Distro CentOS Linux release 7.9.2009 (Core)
Kernel 3.10.0-1160.59.1.el7.x86_64
Asterisk 18.10.0
VitalPBX 3.2.2-1
Running:
Asterisk 18.10.0
VitalPBX 3.2.2-1
That’s the expected behavior. The Queues Callback overwrites the IVR when is enabled.
Any way to have an IVR with queue-callback on a queue?
Add the queues Call Back to your IVR, and disable the Queues Callback on your queue.
I can’t find the option to add a Queues CallBack on an IVR entire.
Please advise how this can be accomplished?
Thank you.
Have you watched this video? I think this will help you understand how Queue Callback is implemented.
It doesn’t say anywhere in the video how to add a Queue CallBack in an IVR.
@PitzKey did you read the first message,
I’m trying to give users the option to press a number for a callback or another option to leave a voicemail.
I need queues CallBack in an IVR to work, @miguel. Please advise how to implement it.
Thank you.
You must add a queue callback item as part of the IVR entries. In sort, use the callback as a destination.
I have not seen the Queue CallBack option in IVR entries because “CallBack Queue” has to be set to a queue and can’t be set to “Same Queue.”
