Provisioning Templates
Is it possible for you guys to change the default template for each phone to set the BLF Feature to either “Line Key” or “None”? And also change the “Account” key to just “Account 1” instead of listing all the accounts in order that each device is capable of?
The Account key for the majority of everyone is always to going to be “Account 1” unless there are any special cases needed for multiple accounts on a single device. In that case, it’s still easier to create those “One-Off” cases on an As-Needed basis instead of having to go and change all the accounts back to "Account 1’ for every template that we create. Especially when dealing with a multi-tenant system, this can be very time costing.
For which models you need that change?
Primary…
  • Yealink
  • Grandstream
  • Cisco
But honestly, this should be for all manufacturers and devices. Having to go through whatever template we create and have to change all those settings back to Account 1 takes up an extreme amount of time.
Thank you for the feedback, I estimate we can launch an update in around 2 weeks.
We’ll keep you posted
