I am migrating to VitalPBX from another Asterisk-based multi-tenant platform. While I recognize older Cisco SPA devices are end of life, I still have lots of them in the field. Can provisioning templates be created for these?
The answer will likely be that it is not on the roadmap.
However, you can use any template that generates the files in a similar filename as cisco expects and then modify the custom tab to contain the cisco config.
