Provisioning: Fanvil Side Keys issue
VALUE on SIDE KEYS on any Fanvil Phone must be set manually to SIP1 (or SIP2, SIP3 and so on). The Line column does not do anything.
Thank you for reporting, we’ll look in more detail and add any changes for the next update.
Currently the line column is used for the following key types:
BLF/NEW CALL, BLF/AXFER, BLF/BXFER, BLF/CONF, BLF/DTMF, Voicemail,
Speed Dial, Presence, Call Park, Intercom, Call Forward
If you need any other type you can ignore it.
I don’t understand it. I am sorry.
The screenshot i sent is the solution how to get the Line keys to be real line keys. VALUE needs to be SIP1 (SIP2, SIP3 … for example). Right now the type Line on Side keys is not working in Vitalpbx.
That was just my hint to show how to fix this.
KR
