When creating a PJSIP extension, upload a firmware, create a template for a SNOM D735 and finally a provisioning record for the that test extension and template, we get the below error. I have tried to remove the template and provision record multiple times and the error re occurs.
Exception: [500-get] {https://127.0.0.1/provisioning/api/provision/00:04}: {“message”:“[/usr/share/provisioning/storage/framework/views/312f585d42c0ef98daa9c719fb35132194805fe3.php:243] Trying to access array offset on value of type null (View: /usr/share/provisioning/storage/framework/views/8c23bfd933114898fc629971d3226caaa87f459e.blade.php)”} at file /usr/share/vitalpbx/www/includes/components/provisioning/RestClient.php on line 0
Only via the PBX webGUI, no changes to the file itself. The only change we made was to the first key for the line and change time zone. We have tried a different model but same problem and get the same issue.
