Provisioning 4.5.1-4 - Fanvil X4U and X6U errors
Provisioning version 4.5.1-4, there is a bug in this version when setting BLF Keys in both the side key and DSS sections when choosing BLF/BXFER
The extension title is added to the config after the key type in the template which makes the value wrong and the setting doesn’t work.
If you choose BLF/AXFER there is no issue as you can see in the screenshots.
Thanks for bring this to our attention. We will fix it in future updates!
This is a change that was requested by a customer, we’ll need to investigate
From the phones web interface that part is added if you add a pickup number, it shouldnt be added to the template if no pickup number is set in the DSS key form though. So I guess the issue is its being set in this version by default even without a pickup number set which is not how its supposed to work. If we leave the pickup number empty in the vitalpbx dss key form nothing extra should be added just like how it worked before.
Understood, thank you for the feedback
