When a queue has a prefix, and the final destination is a voicemail.
Users will not see the prefix on the caller ID in the email.
Vs. when using a CID Modifier with a prefix it will include in the voicemail email the prefix.
Is that how it’s sposed to behave?
Any way I can have one number two queues in the voicemails email should include the prefix?
A company with multiple departments, one main number, and one dispatcher to pick up and direct calls. Each queue has a prefix with the department name, so when the agent gets the call, they know to which department it should get directed. When anyone reaches the voicemail, it is delivered to the dispatcher’s email. Still, the prefix is not included in the caller ID so the dispatcher is not sure which department the voicemail belongs to.
Solutions
We need to create a file under “/etc/asterisk/vitalpbx” path. Name the file “extensions__{ANYNUMBER}-custom-cid-prefix.conf” where {ANYNUMBER} is a consecutive number that represents the order in the asterisk that will read the files, add the code below to the file.
[custom-cid-prefix] exten => _[0-9a-zA-Z].,1,NoOp(Custom dialplan do set cid prefix) same => n,Set(CALLERID(name)=${EXTEN}: ${CALLERID(name)}) same => n,Return()
Install the Custom Contexts add-on if you don’t have it yet, and create a new entery
Description: is a description
Context: custom-cid-prefix
Extension: write whatever the prefix should be
Destination: where you want the system to go next, assuming a voicemail.
