I haven’t tried this command from the CLI. I will give it a try though. Is it just reboot-polycom? I would think I would need a MAC ID with he command?
So I got into the CLI which keeps showing a continuous warning about res_musiconhold though, it allows me to type at the command line. I entered the line and it doesn’t display any errors nor does the phone restart/reboot.
I’ve entered it as ```
pjsip send notify polycom-reboot endpoint
It’s on a multitenant so “smithss106” is the tenant prefix followed by extension number.
I did try both methods. 106 and smiths106. It’s multi tenant, so I assumed smiths would be required in front of the extension to differentiate which tenant it’s for. Will keep digging around.
Thanks for helping. Let me know if there is anything else I can try.
