Please add password reset/forgot password for Sonata Suite.
An admin can reset a user’s password from the GUI. Or if the admin lost access, they can reset the password from shell.
Assuming this is feature request, then please change the category to wish-list.
Ok. I’ve changed to wish list.
Not ideal for the Admin to be doing password resets.
In the IT world? Yes it is!
However, I agree, the user portal should have some kind of password reset mechanism or integration with Active Directory etc.
Any word from Vital about adding this?
I find that even as an Admin, I get locked out.
As has been mentioned, you can use the shell commands to reset the admin password o any other user’s password.
In a short time, there are no plans to add a recovery feature to the PBX GUI.
And for the Sonata root/database password… how can I reset that? Is that somewhere in the docs? I cannot find it.
Would that just be a mysql/postgres command?
Does it impact functionality of any other parts of VPBX… or just Sonata?
Hi @JO_CPA,
Can you please elaborate on which of the sonata applications you are referring to?
Also, out of curiosity, what happened that you need to reset the password? I had set no password and it’s working fine ever since.
If you are going to install it on the same server where VitalPBX is, it does not need a password, it is left blank.
