PJSIP Transports
Good evening,
Is it possible to have two separate transports one pointing to one ip lets say
192.168.5.250 and the other one to 192.168.5.251 so i can have two separate sip trunks register at the same time from the same provider one locally and one via my wireguard VPN?
Thank you.
The short answer is yes. You can specify each transport to listen on what IP.
With that being said, I wouldn’t run a Trunk on wireguard.
Ok thanks,
The reason behind the no trunk via wireguard?
RTP Requires low latency and stability.
What do you recommend as a better scenario to transfer a SIP trunk from point A to point B?
WAN to WAN firewall rules.
