PJSIP Contact dashboard problem again
Running VitalPBX 4.5.2-1 on DigitalOcean Debian 12. I posted before about my dashboard not showing registered contacts correctly and the fix was systemctl restart vpbx-monitor.service. The problem keeps coming back though so I dug deeper and found two things in the logs.
First one is my GUI session disconnects randomly. Sometimes after 2 minutes, sometimes I stay connected all night. No pattern at all. Found this in the logs:
The token seems to be expired!
Connection from: 127.0.0.1 was rejected
Second one is the AMI connection drops several times a night on its own:
Trying to reconnect to AMI in 10 seconds
The Asterisk Manager Connection was closed
Both issues seem to be related to vpbx-monitor being unstable. Restarting the service fixes it temporarily but it comes back. Is there a known issue with the JWT token lifetime or the AMI connection stability in 4.5?
