PHP CVE-2026-126714
what about a patch for PHP CVE-2026-126714?
Already covered by Debian 12 Security Updates:
php8.2 (8.2.36-1~deb12u1) bookworm-security; urgency=high
  • Non-maintainer upload by the LTS Team.
  • New upstream version 8.2.36:
    • [CGI] Fix CVE-2026-129538: PHP-CGI out-of-bounds read and write during
      PATH_INFO correction.
    • [Date] Fix CVE-2026-129496: Timezone cache use-after-free can lead to
      remote code execution.
    • [FPM] Fix CVE-2026-129289: PHP-FPM request smuggling through an unread
      HTTP request body.
    • [FPM] Fix CVE-2026-129292: PHP-FPM status endpoint XSS via unescaped
      user and script fields.
    • [FPM] Fix CVE-2026-129291: PHP-FPM epoll use-after-free can lead to
      local privilege escalation.
    • [Phar] Fix CVE-2026-128090: PHAR OpenSSL signature bypass via algorithm
      downgrade.
      + [Session] Fix CVE-2026-126714: Partially overwritten session files can
      lead to remote code execution.
    • [Session] Fix CVE-2026-115560: Session serializer mismatch can lead to
    • [SOAP] Fix CVE-2026-15353: SOAP information disclosure through malformed
      array dimensions.
    • [SOAP] Fix CVE-2026-129506: SOAP use-after-free when processing DTD
      entity references.
    • Fix CVE-2026-128064: Mixed-case HTTPS and FTPS URLs can expose data in
      plaintext.
    • Fix CVE-2026-127960: Denial of service through folded HTTP response
      headers.
So apt update and apt upgrade
