Ok cool thanks for that xlsx! I see a lot of these arenât in the config screen and Iâm having to input them by hand. Cool.
Question: when setting the server address for static provisioning, what is the variable (and where can I see a list of them?) to do like mypbx.mydomain.com/phoneprov/mytenantprovid?
(looks like mo10 above asked for this back in March as well)
Looks like I might have found a working variable . I do wish you guys had a list of them ready for us to read over though! Also it appears anything you put in these templates are case sensitive. IE: âDownload mode :1â doesnât work but âDownload Mode :1â does. Fun times!
We reboot all our phones across all our estates every night.
I do wish you guys would make input fields in the provisioning templates section for these options. This as well as the following:
-Ring tone
-Power LED notifications
-Time and date format 24 hour vs 12 hour
-Screen dimming timeout
-Provisioning options (on reboot or every x hours)
-Provisioning method (stun, http, https, etc)
-Transfer method used (Blind vs assisted)
-Queue ringtone
Thank you for your feedback, the time format is already planned for a future update, as for the other features listed weâll consider them for future updates
