Phone provisioning grandstream 1610
Hi all,
Why can’t the vitalpbx phone book be loaded on the Grandstream 1610 iPhone?
Hi Sir & @miguel
Why phonebook not working on GXP 1610
This the config file
<?xml version="1.0" encoding="UTF-8" ?>
<!-- Grandstream XML Provisioning Configuration -->
<gs_provision version="1">
	<config version="1">
	<!-- ## Configuration Template For GXP1610/1620/1625/1628/1630 Firmware Version 1.0.4.152          ## -->
	<!-- # Account Settings                                                ## -->
	<!-- # Account 1                                                       ## -->
	<!-- # Account 1/General Settings -->
	<!-- # Account Active. 0 - No, 1 - Yes. Default is 1 -->
	<!-- # Number: 0, 1 -->
	<!-- # Mandatory -->
	<P271>1</P271>
	<!-- # Account Name -->
	<!-- # String -->
	<P270>Bos</P270>
	<!-- # SIP Server -->
	<!-- # String -->
	<P47>149.218.218.92</P47>
	<!-- # Secondary SIP Server -->
	<!-- # String -->
	<P2312></P2312>
	<!-- # Outbound Proxy -->
	<!-- # String -->
	<P48></P48>
	<!-- # Backup Outbound Proxy -->
	<!-- # String -->
	<P2333></P2333>
	<!-- # BLF Server -->
	<!-- # String -->
	<P2375></P2375>
	<!-- # SIP User ID -->
	<!-- # String -->
	<P35>301</P35>
	<!-- # Authenticate ID -->
	<!-- # String -->
	<P36>301</P36>
	<!-- # Authenticate Password -->
	<!-- # String -->
	<P34>4WgCFSWJaA8apZsFDeSKCtw8W</P34>
	<!-- # Name -->
	<!-- # String -->
	<P3>Bos</P3>
	<!-- # Voice Mail Access Number -->
	<!-- # String -->
	<P33></P33>
	<!-- # Account Display -->
	<!-- # Number: 0 - User Name, 1 - User ID. Default is 0. -->
	<P2380>0</P2380>
	<!-- # Account 1/Network Settings -->
	<!-- # DNS Mode. 0 - A Record, 1 - SRV, 2 - NAPTR/SRV, 3 - Use Configured IP. Default is 0 -->
	<!-- # Number: 0, 1, 2, 3 -->
	<P103>0</P103>
	<!-- # Primary IP. Maximum 15 characters -->
	<!-- # String -->
	<P2308></P2308>
	<!-- # Backup IP 1 -->
	<!-- # String -->
	<P2309></P2309>
	<!-- # Backup IP 2 -->
	<!-- # String -->
	<P2310></P2310>
	<!-- # NAT Traversal. 0 - No, 1 - STUN, 2 - keep alive, 3 - UPnP, 4 - Auto, 5 - VPN. Default is 0. -->
	<!-- # Number: 0, 1, 2, 3, 4, 5 -->
	<P52>0</P52>
	<!-- # Proxy-Require (A SIP extension to enable firewall penetration). Max length is 64 characters -->
	<!-- # String -->
	<P197></P197>
	<!-- # Use SBC. 0 - No, 1 - Yes. Default is 0 -->
	<P26090>0</P26090>
	<!-- # Account 1/SIP Settings/Basic Settings -->
	<!-- # TEL URI. 0 - Disabled, 1 - User=Phone, 2 - Enabled. Default is 0 -->
	<!-- # Number: 0, 1, 2 -->
	<P63>0</P63>
	<!-- # SIP Registration. 0 - No, 1 - Yes. Default is 1 -->
	<P31>1</P31>
	<!-- # Unregister On Reboot. 0 - No, 1 - All, 2-Instance. Default is 0 -->
	<P81>0</P81>
	<!-- # Register Expiration (in minutes). Default is 60. Max about 45 days -->
	<!-- # Number: 1 - 64800 -->
	<P32>60</P32>
	<!-- # Subscribe Expiration (in minutes). Default is 60. Max about 45 days -->
	<P26051>60</P26051>
	<!-- # Reregister Before Expiration (in seconds). Default is 0 second -->
	<!-- # Number: 0 - 64800 -->
	<P2330>0</P2330>
	<!-- # Enable OPTIONS Keep Alive -->
	<P2397>0</P2397>
	<!-- # OPTIONS Keep Alive Interval (in seconds). Default is 30 seconds -->
	<!-- # Number -->
	<P2398>30</P2398>
	<!-- # OPTIONS Keep Alive Max Lost (number of max lost packets). Default is 3 -->
	<!-- # Number -->
	<P2399>3</P2399>
	<!-- # Local SIP Port. Default is 5060 -->
	<!-- # Number -->
	<P40>5060</P40>
	<!-- # SIP Registration Failure Retry Wait Time (in seconds). Default is 20 -->
	<!-- # Number: 1 - 3600 -->
	<P138>20</P138>
	<!-- # SIP T1 Timeout. RFC 3261 T1 value (RTT estimate) -->
	<!-- # 50 - 0.5 sec, 100 - 1 sec, 200 - 2 sec. Default is 50 -->
	<!-- # Number: 50, 100, 200 -->
	<P209>50</P209>
	<!-- # SIP T2 Timeout. RFC 3261 T2 value. The maximum retransmit interval for non-INVITE requests and INVITE responses -->
	<!-- # 200 - 2 sec, 400 - 4 sec, 800 - 8 sec. Default is 400 -->
	<!-- # Number: 200, 400, 800 -->
	<P250>400</P250>
	<!-- # Switch Backup Proxy on No Response. 0 - No, 1 - Yes. Default is 0 -->
	<P26092>0</P26092>
	<!-- # SIP Transport. 0 - UDP, 1 - TCP, 2 - TLS/TCP. Default is 0 -->
	<P130>0</P130>
	<!-- # SIP URI Scheme when using TLS. 0 - sip, 1 - sips. Default is 1 -->
	<P2329>1</P2329>
	<!-- # Use Actual Ephemeral Port in Contact with TCP/TLS. 0 - No, 1 - Yes. Default is 0 -->
	<P2331>0</P2331>
	<!-- # Outbound Proxy Mode. 0 - in route, 1 - not in route, 2 - always send to. Default is 0 -->
	<P2305>0</P2305>
	<!-- # Support SIP Instance ID. 0 - No, 1 - Yes. Default is 1 -->
	<P288>1</P288>
	<!-- # SUBSCRIBE for MWI. 0 - No, 1 - Yes. Default is 0 -->
	<P99>0</P99>
	<!-- # SUBSCRIBE for Registration. 0 - No, 1 - Yes. Default is 0 -->
	<P2319>0</P2319>
	<!-- # Enable 100rel. 0 - No, 1 - Yes. Default is 0 -->
	<P272>0</P272>
	<!-- # Callee ID Display. 0 - Auto, 1 - Disabled, 2 - To Header. Default is 0 -->
	<P26025>0</P26025>
	<!-- # Caller ID Display. 0 - Auto, 1 - Disabled, 2 - From Header. Default is 0 -->
	<P2324>0</P2324>
	<!-- # Ignore Alert-Info header -->
	<!-- # 0 - No, 1 - Yes. Default is 0 -->
	<!-- # Number 0,1 -->
	<P26018>0</P26018>
	<!-- # Add Auth Header On Initial REGISTER -->
	<P2359>0</P2359>
	<!-- # Account 1/SIP Settings/Custom SIP Headers -->
	<!-- # Use Privacy Header -->
	<!-- # 0 - Default, 1 - No, 2 - Yes. Default is 0 -->
	<P2338>0</P2338>
	<!-- # Use P-Preferred-Identity Header -->
	<P2339>0</P2339>
	<!-- # Use X-Grandstream-PBX Header -->
	<!-- # 0 - No, 1 - Yes. Default is 1 -->
	<P26054>1</P26054>
	<!-- # Use P-Access-Network-Info Header -->
	<P26058>1</P26058>
	<!-- # Use P-Emergency-Info Header -->
	<P26059>1</P26059>
	<!-- # Use MAC Header -->
	<!-- # 0 - No, 1 - Yes except REGISTER, 2 - Yes to all SIP. Default is 0 -->
	<P26061>0</P26061>
	<!-- # Account 1/SIP Settings/Advanced Features -->
	<!-- # Line-seize Timeout (in seconds). Default is 15 -->
	<!-- # Number: 15-60 -->
	<P2313>15</P2313>
	<!-- # Eventlist BLF URI. For GXP1630/1628 only -->
	<!-- # String -->
	<P134></P134>
	<!-- # Auto Provision Eventlist BLFs. For GXP1630/1628 only. 0 - disabled, 1 - enabled.  -->
	<!-- # Default is 0 -->
	<P2389>0</P2389>
	<!-- # Conference URI -->
	<!-- # String -->
	<P2318></P2318>
	<!-- # Music On Hold URI -->
	<!-- # String -->
	<P2350></P2350>
	<!-- # Force BLF Call-pickup by prefix. For GXP1630/1628 only. 0 - No, 1 - Yes. Default is 0  -->
	<P6752>0</P6752>
	<!-- # BLF Call-pickup Prefix. For GXP1630/1628 only. -->
	<!-- # String. Defaule is "**" -->
	<P1347>**</P1347>
	<!-- # Call Pickup Barge-In Code. For GXP1630/1628 only. -->
	<!-- # String  -->
	<P26046></P26046>
	<!-- # PUBLISH for Presence. 0 - No, 1 - Yes. For GXP1630/1628 only. -->
	<P188>0</P188>
	<!-- # Enable User Presence Subscription -->
	<!-- # Number: 0 - No, 1 - Yes. Default is 0. -->
	<P2353>0</P2353>
	<!-- # Hide Login Soft Key On Auto User Presence Subscription -->
	<!-- # Number: 0 - No, 1 - Yes. Default is 1. -->
	<P2354>1</P2354>
	<!-- # Auto User Presence ID -->
	<!-- # String -->
	<P2351></P2351>
	<!-- # Auto User Presence Password -->
	<!-- # String -->
	<P2352></P2352>
	<!-- # Special Feature. 100 - Standard, 101 - Nortel MCS, 102- Broadsoft, 108 - CBCOM,  -->
	<!-- # 109 - RNK, 110 - Sylantro, 117 - Huawei IMS, 119 - Phonepower -->
	<!-- # Default is 100 -->
	<!-- # Number: 100, 101, 102, 108, 109, 110, 117, 119 -->
	<P198>100</P198>
	<!-- # Broadsoft Call Center. 0 - No, 1 - Yes. Default is 0 -->
	<P2341>0</P2341>
	<!-- # Hoteling Event. 0 - No, 1 - Yes. Default is 0 -->
	<P2342>0</P2342>
	<!-- # Call Center Status. 0 - No, 1 - Yes. Default is 0 -->
	<P2343>0</P2343>
	<!-- # Feature Key Synchronization. 0 - Disabled, 1 - Enabled. Default is 0 -->
	<P2325>0</P2325>
	<!-- # Broadsoft Call Park -->
	<!-- # Number 0 - Disabled, 1 - Enabled. Default is 0 -->
	<P2388>0</P2388>
	<!-- # Account 1/SIP Settings/Session Timer -->
	<!-- # Enable Session Timer. 0 - No, 1 - Yes. Default is 1 -->
	<P2395>1</P2395>
	<!-- # Session Expiration (in seconds). Default is 180 -->
	<!-- # Number: 90 - 64800 -->
	<P260>180</P260>
	<!-- # Minimum SE (in seconds). Default is 90. This value must be lower than or equal to P260 -->
	<P261>90</P261>
	<!-- # Caller Request Timer (Request for timer when calling). 0 - No, 1 - Yes. Default is 0 -->
	<P262>0</P262>
	<!-- # Callee Request Timer (Request for timer when called. i.e. if remote party supports timer but did not request for one) -->
	<P263>0</P263>
	<!-- # Force Timer (Still use timer when remote party does not support timer). 0 - No, 1 - Yes. Default is 0 -->
	<P264>0</P264>
	<!-- # UAC Specify Refresher. 0 - omit, 1 - UAC, 2 - UAS. Default is 0 -->
	<P266>0</P266>
	<!-- # UAS Specify Refresher. 1 - UAC, 2 - UAS. Default is 1 -->
	<!-- # Number: 1, 2 -->
	<P267>1</P267>
	<!-- # Force INVITE (Always refresh with INVITE instead of UPDATE even when remote party supports UPDATE). -->
	<P265>0</P265>
	<!-- # Account 1/SIP Settings/Security Settings -->
	<!-- # Check Domain Certificates. When set to Yes/Enabled, domain certificate will be checked as defined in RFC5922 -->
	<P2311>0</P2311>
	<!-- # Validate Certification Chain. 0 - No, 1 - Yes. Default is 0 -->
	<!-- # NUmber: 0, 1 -->
	<P2367>0</P2367>
	<!-- # Validate Incoming Messages. 0 - No, 1 - Yes. Default is 0 -->
	<P2306>0</P2306>
	<!-- # Check SIP User ID for incoming INVITE. 0 - No, 1 - Yes. Default is 0 -->
	<P258>0</P258>
	<!-- # Accept Incoming SIP from Proxy Only. 0 - No, 1 - Yes. Default is 0 -->
	<P2347>0</P2347>
	<!-- # Authenticate Incoming INVITE. 0 - No, 1 - Yes. Default is 0 -->
	<P2346>0</P2346>
	<!-- # Account 1/Audio Settings -->
	<!-- # Send DTMF: In-audio. 0 - No, 1 - Yes. Default is 0 -->
	<P2301>0</P2301>
	<!-- # Send DTMF: Via RTP (RFC2833). 0 - No, 1 - Yes. Default is 1 -->
	<P2302>1</P2302>
	<!-- # Send DTMF: Via SIP INFO. 0 - No, 1 - Yes. Default is 0 -->
	<P2303>0</P2303>
	<!-- # DTMF Payload Type. Default is 101 -->
	<!-- # Number: 96 - 127 -->
	<P79>101</P79>
	<!-- # Preferred Vocoder -->
	<!-- # 0 - PCMU, 2 - G.726-32, 4 - G.723.1, 8 - PCMA, 9 - G.722, 18 - G.729A/B, 98 - iLBC -->
	<!-- # choice 1. Default is 0 -->
	<!-- # Number: 0, 2, 4, 8, 9, 18, 98 -->
	<P57>0</P57>
	<!-- # choice 2. Default is 8 -->
	<P58>8</P58>
	<!-- # choice 3. Default is 18 -->
	<P59>18</P59>
	<!-- # choice 4. Default is 9 -->
	<P60>9</P60>
	<!-- # choice 5. Default is 2 -->
	<P61>2</P61>
	<!-- # choice 6. Default is 2 -->
	<P62>2</P62>
	<!-- # choice 7. Default is 2 -->
	<P46>2</P46>
	<!-- # Use First Matching Vocoder in 200OK SDP. 0 - No, 1 - Yes. Default is 0 -->
	<P2348>0</P2348>
	<!-- # Codec Negotiation Priority. 0 - Caller, 1 - Callee. Default is 1 -->
	<P29061>1</P29061>
	<!-- # Disable Multiple m line in SDP. 0 - No, 1 - Yes. Default is 0 -->
	<P137>0</P137>
	<!-- # SRTP Mode. 0 - Disabled, 1 - Enabled but not forced, 2 - Enabled and forced, 3 - Optional. Default is 0 -->
	<P183>0</P183>
	<!-- # Symmetric RTP. 0 - No, 1 - Yes. Default is 0 -->
	<P291>0</P291>
	<!-- # Silence Suppression. 0 - No, 1 - Yes. Default is 0 -->
	<P50>0</P50>
	<!-- # Voice Frames per TX (up to 10/20/32/64 frames for G711/G726/G723/other codecs respectively). Default is 2 -->
	<!-- # Number: 1 - 64 -->
	<P37>2</P37>
	<!-- # G723 Rate. 0 - 6.3kbps, 1 - 5.3 kbps. Default is 0 -->
	<P49>0</P49>
	<!-- # G.726-32 Packing Mode. 0 - ITU, 1 - IETF. Default is 0 -->
	<P2323>0</P2323>
	<!-- # iLBC Frame Size, 0 - 20ms, 1 - 30ms. Default is 1. -->
	<P97>1</P97>
	<!-- # iLBC Payload Type, Default is 97 -->
	<P96>97</P96>
	<!-- # Jitter Buffer Type. 0 - Fixed, 1 - Adaptive. Default is 1 -->
	<P133>1</P133>
	<!-- # Jitter Buffer Length. 0 - 100ms, 1 - 200ms, 2 - 300ms, 3 - 400ms, 4 - 500ms, 5 - 600ms, 6 - 700ms, 7 - 800ms -->
	<!-- # Default is 2 -->
	<!-- # Number: 0, 1, 2, 3, 4, 5, 6, 7 -->
	<P132>2</P132>
	<!-- # Hide Vocodec. 0 - No, 1 - Yes. Default is 0. -->
	<P26047>0</P26047>
	<!-- # Account 1/Call Settings -->
	<!-- # Early Dial (use "Yes" only if proxy supports 484 response). 0 - No, 1 - Yes. Default is 0 -->
	<P29>0</P29>
	<!-- # Dial Plan Prefix -->
	<!-- # String  -->
	<P66></P66>
	<!-- # Dial Plan. Default is { x+ | *x+ | *xx*x+ } -->
	<!-- # String -->
	<P290>{ x+ | *x+ | *xx*x+ }</P290>
	<!-- # Bypass Dial Plan. Default is Mpk -->
	<!-- # String: Contact, Call History Incoming Call, Call History Outgoing Call, Dialing Page, Mpk, Api -->
	<!-- # P2382 = Mpk -->
	<!-- # Call Log. 0 - Log All, 1 - Log Incoming/Outgoing only (Missed calls NOT recorded), 2 - Disable Call Log. Default is 0 -->
	<P182>0</P182>
	<!-- # Send Anonymous (caller ID will be blocked if set to Yes). 0 - No, 1 - Yes. Default is 0 -->
	<P65>0</P65>
	<!-- # Anonymous Call Rejection. 0 - No, 1 - Yes. Default is 0 -->
	<P129>0</P129>
	<!-- # Auto Answer. 0 - No, 1 - Yes. Default is 0 -->
	<P90>0</P90>
	<!-- # Refer-To Use Target Contact. 0 - No, 1 - Yes. Default is 0 -->
	<P135>0</P135>
	<!-- # Transfer on conference Hang-Up. 0 - No, 1 - Yes. Default is 0 -->
	<P2304>0</P2304>
	<!-- # Disable Recovery on Blind Transfer, 0 - No, 1- Yes. Default is 0 -->
	<P2384>0</P2384>
	<!-- # Blind Transfer Wait Timeout, in seconds. Default is 30 -->
	<!-- # Number: 30 - 300 -->
	<P26070>30</P26070>
	<!-- # No Key Entry Timeout (in seconds). Default is 4 -->
	<!-- # Number: 1 - 15 -->
	<P85>4</P85>
	<!-- # Key as Send. 0 - Disable, 1 - Pound (#). Default is 1 -->
	<P72>1</P72>
	<!-- # On Hold Reminder Tone.  0 - Disabled, 1 - Enabled. Default is 0 -->
	<P26006>0</P26006>
	<!-- # Call Recording ON -->
	<!-- # String -->
	<P26028></P26028>
	<!-- # Call Recording OFF -->
	<!-- # String -->
	<P26029></P26029>
	<!-- # Hide Dialing Password - Prefix for Dialing Password -->
	<!-- # String -->
	<P26049></P26049>
	<!-- # Hide Dialing Password - Password Length. Default is 0. -->
	<!-- # Number: 1 - 32 -->
	<P26050>0</P26050>
	<!-- # Remote Info Display -->
	<!-- # 0 - Name and Number, 1 - Number, 2 - Name. Default is 0 -->
	<P26076>0</P26076>
	<!-- # Hide Remote User ID - Call Type. 0 - None of Call, 1 - Incoming Calls, 2 - Outgoing Calls, 3 - Both Directions. Default is 0 -->
	<!-- # Number: 0 - 3 -->
	<P26043>0</P26043>
	<!-- # Hide Remote User ID - Length -->
	<!-- # Number: 0 ... N -->
	<P26044>0</P26044>
	<!-- # Account Ring Tone. 0 - System Ringtone, 1 - Custom Ringtone 1, 2 - Custom Ringtone 2, 3 - Custom Ringtone 3 -->
	<!-- # 6 - Custom Ringtone 4, 7 - Custom Ringtone 5, 8 - Custom Ringtone 6, 9 - Custom Ringtone 7, 10 - Custom Ringtone 8 -->
	<!-- # 11 - Custom Ringtone 9, 12 - Custom Ringtone 10, 4 - Silent, 5 - Default Ringtone -->
	<!-- # Default is 5 -->
	<!-- # Number: 0 - 12 -->
	<P104>5</P104>
	<!-- # Matching Incoming Caller ID. Matching Rule 1 -->
	<!-- # String -->
	<P1488></P1488>
	<!-- # Matching Rule 1 Distinctive Ringtone -->
	<!-- # 0 - System Ringtone, 1 - Custom Ringtone 1, 2 - Custom Ringtone 2, 3 - Custom Ringtone 3 -->
	<P1489>0</P1489>
	<!-- # Matching Incoming Caller ID. Matching Rule 2 -->
	<!-- # String -->
	<P1490></P1490>
	<!-- # Matching Rule 2 Distinctive Ringtone -->
	<P1491>0</P1491>
	<!-- # Matching Incoming Caller ID. Matching Rule 3 -->
	<!-- # String -->
	<P1492></P1492>
	<!-- # Matching Rule 3 Distinctive Ringtone -->
	<P1493>0</P1493>
	<!-- # Matching Incoming Caller ID. Matching Rule 4 -->
	<!-- # String -->
	<P6716></P6716>
	<!-- # Matching Rule 4 Distinctive Ringtone -->
	<P6717>0</P6717>
	<!-- # Matching Incoming Caller ID. Matching Rule 5 -->
	<!-- # String -->
	<P6718></P6718>
	<!-- # Matching Rule 5 Distinctive Ringtone -->
	<P6719>0</P6719>
	<!-- # Matching Incoming Caller ID. Matching Rule 6 -->
	<!-- # String -->
	<P6720></P6720>
	<!-- # Matching Rule 6 Distinctive Ringtone -->
	<P6721>0</P6721>
	<!-- # Matching Incoming Caller ID. Matching Rule 7 -->
	<!-- # String -->
	<P26064></P26064>
	<!-- # Matching Rule 7 Distinctive Ringtone -->
	<P26065>0</P26065>
	<!-- # Matching Incoming Caller ID. Matching Rule 8 -->
	<!-- # String -->
	<P26066></P26066>
	<!-- # Matching Rule 8 Distinctive Ringtone -->
	<P26067>0</P26067>
	<!-- # Matching Incoming Caller ID. Matching Rule 9 -->
	<!-- # String -->
	<P26068></P26068>
	<!-- # Matching Rule 9 Distinctive Ringtone -->
	<P26069>0</P26069>
	<!-- # Matching Incoming Caller ID. Matching Rule 10 -->
	<!-- # String -->
	<P26096></P26096>
	<!-- # Matching Rule 10 Distinctive Ringtone -->
	<P26097>0</P26097>
	<!-- # Ring Timeout (in seconds). Default is 60 -->
	<!-- # Number: 30 - 3600 -->
	<P1328>60</P1328>
	<!-- # Account 1/Intercom Settings -->
	<!-- # Allow Auto Answer by Call-Info/Alert-Info. 0 - No, 1 - Yes. Default is 0 -->
	<P298>0</P298>
	<!-- # Mute on answer Intercom call. 0 - No, 1 - Yes. Default is 0 -->
	<P26071>0</P26071>
	<!-- # Play warning tone for Auto Answer Intercom. 0 - No, 1 - Yes. Default is 0 -->
	<P26072>0</P26072>
	<!-- # Custom Call-Info for Auto Answer -->
	<!-- # String -->
	<P2356></P2356>
	<!-- # Account 1/Feature Codes -->
	<!-- # Enable Local Call Features.  0 - No, 1 - Yes. Default is 1 -->
	<P191>0</P191>
	<!-- # DND Call Feature ON -->
	<!-- # String -->
	<P2344></P2344>
	<!-- # DND Call Feature OFF -->
	<!-- # String -->
	<P2345></P2345>
	<!-- # Call Forward Unconditionally (All) ON -->
	<!-- # String -->
	<P26013></P26013>
	<!-- # Call Forward Unconditionally (All) - OFF -->
	<!-- # String -->
	<P26014></P26014>
	<!-- # Call Forward Busy - ON -->
	<!-- # String -->
	<P26009></P26009>
	<!-- # Call Forward Busy - OFF -->
	<!-- # String -->
	<P26010></P26010>
	<!-- # Call Forward Delayed (No Answer) - ON -->
	<!-- # String -->
	<P26011></P26011>
	<!-- # Call Forward Delayed (No Answer) - OFF -->
	<!-- # String -->
	<P26012></P26012>
	<!-- # Delayed Call Forward Wait Time -->
	<!-- # Number: 1 - 120. Default is 20. -->
	<P139>20</P139>
	<!-- ## Network/Basic Settings                                                   ## -->
	<!-- # Internet Protocol. 0 - Both, Prefer IPv4, 1 - Both, Prefer IPv6, 2 - IPv4 Only, 3 - IPv6 Only. Default is 0 -->
	<P1415>0</P1415>
	<!-- # IP Address Mode. 0 - DHCP, 1 - Static IP, 2 - PPPoE. Default is 0 -->
	<P8>0</P8>
	<!-- # DHCP -->
	<!-- # Host name, DHCP option 12. Max length allowed is 64 characters -->
	<!-- # String -->
	<P146></P146>
	<!-- # Vendor Class ID, DHCP option 60. Max length allowed is 64 characters -->
	<!-- # Default value for GXP1610 - Grandstream GXP1610 -->
	<!-- # Default value for GXP1620 - Grandstream GXP1620 -->
	<!-- # Default value for GXP1625 - Grandstream GXP1625 -->
	<!-- # Default value for GXP1625 - Grandstream GXP1628 -->
	<!-- # Default value for GXP1625 - Grandstream GXP1630 -->
	<!-- # String -->
	<!-- # Cannot be empty -->
	<!-- # P148 =   -->
	<!-- # PPPoE -->
	<!-- # PPPoE Account ID -->
	<!-- # String -->
	<P82></P82>
	<!-- # PPPoE Password -->
	<!-- # String -->
	<!-- # Cannot contain ` or " -->
	<P83></P83>
	<!-- # PPPoE Service Name -->
	<!-- # String  -->
	<P269></P269>
	<!-- # Statically Configured -->
	<!-- # IP Address. Ignore if DHCP or PPPoE is used -->
	<!-- # Number: 0 - 255 -->
	<P9>192</P9>
	<P10>168</P10>
	<P11>0</P11>
	<P12>160</P12>
	<!-- # Subnet mask. Ignore if DHCP or PPPoE is used -->
	<P13>255</P13>
	<P14>255</P14>
	<P15>255</P15>
	<P16>0</P16>
	<!-- # Gateway. Ignore if DHCP or PPPoE is used -->
	<P17>0</P17>
	<P18>0</P18>
	<P19>0</P19>
	<P20>0</P20>
	<!-- # DNS 1 Server. Ignore if DHCP or PPPoE is used -->
	<P21>0</P21>
	<P22>0</P22>
	<P23>0</P23>
	<P24>0</P24>
	<!-- # DNS 2 Server. Ignore if DHCP or PPPoE is used -->
	<P25>0</P25>
	<P26>0</P26>
	<P27>0</P27>
	<P28>0</P28>
	<!-- # Preferred DNS server.  (if specified). -->
	<P92>0</P92>
	<P93>0</P93>
	<P94>0</P94>
	<P95>0</P95>
	<!-- # IPv6 Address type. 0 - Auto Configured, 1 - Statically Configured. Default is 0. -->
	<P1419>0</P1419>
	<!-- # IPv6 Address type: Statically configured. 0 - Full Static, 1 - Prefix Static -->
	<P1426>0</P1426>
	<!-- # Full Static: Static IPv6 Address -->
	<P1420></P1420>
	<!-- # Full Static: IPv6 Prefix Length -->
	<P1421></P1421>
	<!-- # Prefix Static: IPv6 Prefix (64bits) -->
	<P1422></P1422>
	<!-- # DNS Server 1 for IPv6 Address -->
	<!-- # String: a-z, A-Z, 0-9, ".", ":", "[", "]" -->
	<P1424></P1424>
	<!-- # DNS Server 2 for IPv6 Address -->
	<P1425></P1425>
	<!-- # Preferred DNS Server for IPv6 Address -->
	<P1423></P1423>
	<!-- ## Network/Advanced Settings -->
	<!-- # 802.1X Mode. 0 - disable, 1 - EAP-MD5, 2 - EAP-TLS, 3 - EAP-PEAPv0/MSCHAPv2. Default is 0 -->
	<P7901>0</P7901>
	<!-- # 802.1X Identity. Max length allowed is 64 characters -->
	<!-- # String -->
	<P7902></P7902>
	<!-- # MD5 Password. Max length allowed is 64 characters -->
	<!-- # String -->
	<P7903></P7903>
	<!-- # HTTP Proxy -->
	<!-- # String -->
	<P1552></P1552>
	<!-- # HTTPS Proxy -->
	<!-- # String -->
	<P1553></P1553>
	<!-- # Layer 3 QoS for SIP. Default is 26 -->
	<!-- # Number: 0 - 63 -->
	<P1558>26</P1558>
	<!-- # Layer 3 QoS for RTP. Default is 46 -->
	<P1559>46</P1559>
	<!-- # Enable DHCP VLAN, 0 - Disable, 1 - Enable. Default is 0 -->
	<P8300>0</P8300>
	<!-- # Enable Manual VLAN Configuration. 0 - Disable, 1 - Enable. Default is 1 -->
	<P22174>1</P22174>
	<!-- # Layer 2 QoS. 802.1Q/VLAN Tag (VLAN classification for RTP). Default is 0 -->
	<!-- # Number: 0 - 4094 -->
	<P51>0</P51>
	<!-- # Layer 2 QoS. 802.1p priority value (0 - 7). Default is 0 -->
	<!-- # Number: 0 - 7 -->
	<P87>0</P87>
	<!-- # PC Port Mode. 0 - Enable, 1 - Disabled, 2 - Mirrored. Default is 0 -->
	<P1348>0</P1348>
	<!-- # PC Port VLAN Tag. Default is 0 -->
	<P229>0</P229>
	<!-- # PC Port Priority Value. Default is 0 -->
	<P230>0</P230>
	<!-- # Enable CDP.   0 - Disabled, 1 - Enabled. Default is 0 -->
	<P22119>0</P22119>
	<!-- # Enable LLDP.  0 - Disabled, 1 - Enabled. Default is 1 -->
	<P1684>1</P1684>
	<!-- # Maximum Transmission Unit (MTU) in bytes, default is 1500 bytes -->
	<!-- # Number -->
	<P244>1500</P244>
	<!-- ##  Network/Remote Control -->
	<!-- # CSTA Control. 0 - Disabled, 1 - Enabled -->
	<!-- # Number: 0, 1. Default is 0 -->
	<P32053>0</P32053>
	<!-- ## Network/OpenVPN Settings -->
	<!-- # OpenVPN Enable. 0 - No, 1 - Yes, default is 0 -->
	<!-- # Number -->
	<P7050>0</P7050>
	<!-- # OpenVPN Server Address -->
	<!-- # String -->
	<P7051></P7051>
	<!-- # OpenVPN Port. Default is 1194 -->
	<!-- # Number -->
	<P7052>1194</P7052>
	<!-- # OpenVPN Transport.  0 - UDP, 1 - TCP Default is 0 -->
	<P2912>0</P2912>
	<!-- # OpenVPN CA -->
	<!-- # String -->
	<P9902></P9902>
	<!-- # OpenVPN Certificate -->
	<!-- # String -->
	<P9903></P9903>
	<!-- # OpenVPN Client Key -->
	<!-- # String -->
	<P9904></P9904>
	<!-- # OpenVPN Cipher Method -->
	<!-- # Number: 0 - Blowfish, 1 - AES-128, 2 - AES-256, 3 - Triple-DES. Default is 0. -->
	<P8396>0</P8396>
	<!-- # OpenVPN Username -->
	<!-- # String -->
	<P8394></P8394>
	<!-- # OpenVPN Password -->
	<!-- # String -->
	<P8395></P8395>
	<!-- # OpenVPN Comp-lzo. 0 - No, 1 - Yes. Default is 1 -->
	<P8508>1</P8508>
	<!-- # Additional Options -->
	<!-- # String -->
	<P8460></P8460>
	<!-- # Network/SNMP Settings -->
	<!-- # Enable SNMP -->
	<P21896>0</P21896>
	<!-- # Version. 1 - Version 1, 2 - Version 2, 3 - Version 3. Default is 3 -->
	<!-- # Number: 1, 2, 3 -->
	<P21904>3</P21904>
	<!-- # Port -->
	<!-- # Number -->
	<P21903>161</P21903>
	<!-- # SNMP Trap IP -->
	<!-- # String -->
	<P21897></P21897>
	<!-- # SNMP Trap Port -->
	<!-- # Number: 1025 - 65535. Default is 162. -->
	<P21898>162</P21898>
	<!-- # SNMP Trap Interval -->
	<!-- # Number: 1 - 1440. Default is 5. -->
	<P21901>5</P21901>
	<!-- # SNMP Trap Version -->
	<!-- # Number: 1 - Version 1, 2 - Version 2, 3 - Version 3. Default is 2 -->
	<P21899>2</P21899>
	<!-- # Community -->
	<!-- # String -->
	<P21902></P21902>
	<!-- # SNMP Trap Community -->
	<!-- # String -->
	<P21900></P21900>
	<!-- # SNMP Username -->
	<!-- # String -->
	<P21905></P21905>
	<!-- # Security Level. 0 - noAuthUser, 1 - authUser, 2 - privUser. Default is 0 -->
	<P21910>0</P21910>
	<!-- # Authentication Protocol. 0 - None, 1 - MD5, 2 - SHA. Default is 0 -->
	<P21906>0</P21906>
	<!-- # Privacy Protocol. 0 - None, 1 - DES, 2 - AES. Default is 0 -->
	<P21907>0</P21907>
	<!-- # Authentication Key -->
	<!-- # String -->
	<P21908></P21908>
	<!-- # Private Key -->
	<!-- # String -->
	<P21909></P21909>
	<!-- # SNMP Trap Username -->
	<!-- # String -->
	<P21911></P21911>
	<!-- # Trap Security Level. 0 - noAuthUser, 1 - authUser, 2 - privUser. Default is 0 -->
	<P21916>0</P21916>
	<!-- # Trap Authentication Protocol. 0 - None, 1 - MD5, 2 - SHA. Default is 0 -->
	<P21912>0</P21912>
	<!-- # Trap Privacy Protocol. 0 - None, 1 - DES, 2 - AES. Default is 0 -->
	<P21913>0</P21913>
	<!-- # Trap Authentication Key -->
	<!-- # String -->
	<P21914></P21914>
	<!-- # Trap Private Key -->
	<!-- # String -->
	<P21915></P21915>
	<!-- ##  Maintenance/ Web Access -->
	<!-- # New User Password -->
	<!-- # String: a-z, A-Z, 0-9 -->
	<!-- # P196 = -->
	<!-- # New Admin password for web interface -->
	<P2>1234</P2>
	<!-- ##  Maintenance/Upgrade and Provisioning -->
	<!-- # Firmware Upgrade and Provisioning -->
	<!-- # 0 - Always Check For New Firmware -->
	<!-- # 1 - Check New Firmware only when F/W pre/suffix changes -->
	<!-- # 2 - Always Skip the Firmware Check -->
	<P238>0</P238>
	<!-- # Always Authenticate Before Challenge. 0 - No,  1 - Yes. Default is 0 -->
	<P20713>1</P20713>
	<!-- # Validate Hostname in Certificate. 0 - No,  1 - Yes. Default is 0 -->
	<P22030>0</P22030>
	<!-- # Allow DHCP Option 43 and Option 66 to override server. 0 - No, 1 - Yes. Default is 1 -->
	<!-- # When set to Yes(1), it will override the configured provision path and method -->
	<P145>1</P145>
	<!-- # Additional Override DHCP option -->
	<!-- # 0 - None, 1 - Option 150, 2 - Option 160 -->
	<P8337>0</P8337>
	<!-- # Allow DHCP Option 120 to Override SIP Server -->
	<P1411>0</P1411>
	<!-- # 3CX Auto Provision. 0 - No, 1 - Yes. Default is 1 -->
	<P1414>1</P1414>
	<!-- # Automatic Upgrade -->
	<!-- # 0 - No,  -->
	<!-- # 1 - Yes, check for upgrade based on minute(s) setting, -->
	<!-- # 2 - Yes, check for upgrade based on Hour of Day setting, -->
	<!-- # 3 - Yes, check for upgrade based on Day of Week setting, -->
	<!-- # Default is No. -->
	<P194>0</P194>
	<!-- # Randomized Automatic Upgrade. 0 - No, 1 - Yes. Default is 0 -->
	<P8458>0</P8458>
	<!-- # Check for new firmware every () minutes. Default is 7 days. -->
	<!-- # Number: 60-86400 -->
	<P193>10080</P193>
	<!-- # Hour of the Day (0-23). Default is 1 -->
	<!-- # Number: 0 - 23 -->
	<P285>1</P285>
	<!-- # Day of the Week (0-6). Default is 1 -->
	<!-- # Number: 0-6 -->
	<P286>1</P286>
	<!-- # Disable SIP NOTIFY Authentication. 0 -No, 1 - Yes. Default is 0. -->
	<P4428>0</P4428>
	<!-- # Firmware Upgrade Confirmation. 0 - No, 1 - Yes. Default is 1. -->
	<P8375>1</P8375>
	<!-- # Config Upgrade Via. 0 - TFTP,  1 - HTTP, 2 - HTTPS, 3 - FTP, 4 - FTPS. Default is 1 -->
	<!-- # Number: 0, 1, 2, 3, 4 -->
	<P212>1</P212>
	<!-- # Config Server Path -->
	<!-- # String -->
	<P237>149.218.218.92/phoneprov/db494559b6584de5</P237>
	<!-- # Config HTTP/HTTPS User Name -->
	<!-- # String -->
	<P1360></P1360>
	<!-- # Config HTTP/HTTPS Password -->
	<!-- # String -->
	<P1361></P1361>
	<!-- # Config File Prefix -->
	<!-- # String -->
	<P234></P234>
	<!-- # Config File Postfix -->
	<!-- # String -->
	<P235></P235>
	<!-- # XML Config File Password -->
	<!-- # String -->
	<P1359></P1359>
	<!-- # Authenticate Conf File. 0 - No, 1 - Yes. Default is No -->
	<P240>0</P240>
	<!-- # Firmware Upgrade Via. 0 - TFTP,  1 - HTTP, 2 - HTTPS, 3 - FTP, 4 - FTPS. Default is 1 -->
	<P6767>1</P6767>
	<!-- # Firmware Server Path -->
	<!-- # String -->
	<P192>149.218.218.92/firmwares/GXP1610</P192>
	<!-- # Firmware HTTP/HTTPS User Name -->
	<!-- # String -->
	<P6768></P6768>
	<!-- # Firmware HTTP/HTTPS Password -->
	<!-- # String -->
	<P6769></P6769>
	<!-- # Firmware File Prefix -->
	<!-- # String -->
	<P232></P232>
	<!-- # Firmware File Postfix -->
	<!-- # String -->
	<P233></P233>
	<!-- ##  Maintenance/Syslog -->
	<!-- # Syslog Protocol -->
	<!-- # 0 - UDP, 1 - SSL/TLS. Default is 0 -->
	<P8402>0</P8402>
	<!-- # Syslog Server (name of the server, max length is 64 characters) -->
	<!-- # String -->
	<P207></P207>
	<!-- # Syslog Level. 0 - NONE, 1 - DEBUG, 2 - INFO, 3 - WARNING, 4 - ERROR. Default is 0 -->
	<!-- # Number: 0, 1 , 2, 3, 4 -->
	<P208>0</P208>
	<!-- # Syslog Keyword Filtering -->
	<!-- # String -->
	<P22129></P22129>
	<!-- # Send SIP Log. 0 - Do not send SIP log in Syslog, 1 - Send SIP log in Syslog if configured and set to DEBUG level. Default is 0 -->
	<P1387>0</P1387>
	<!-- ##  Maintenance/Language -->
	<!-- # Display Language. Default is auto -->
	<!-- # ar - Arabic, cs - Czech, de - Deutsh -->
	<!-- # en - English, es - Spanish, fr - Francais -->
	<!-- # he - Hebrew, hr - Hrvatski, hu - Magyar  -->
	<!-- # it - Italiano, ja - japanese, ko - korean -->
	<!-- # lv - Latvian, nl - Dutch, pl - Polski, pt - Portugue -->
	<!-- # ru - Russian, sl - Slovenian, se - Svenska -->
	<!-- # tr - Turkish, zh-tw - traditional chinese,  -->
	<!-- # zh - simplified chinese, auto - Automatic -->
	<!-- # gxp - Downloaded Language -->
	<!-- # String -->
	<P1362>en</P1362>
	<!-- # Language File postfix (for Downloaded Language) -->
	<!-- # String -->
	<P399></P399>
	<!-- ##  Maintenance/Action URL -->
	<!-- # Setup Completed -->
	<!-- # String -->
	<P8304></P8304>
	<!-- # Registered -->
	<!-- # String -->
	<P8305></P8305>
	<!-- # Unregistered  -->
	<!-- # String -->
	<P8306></P8306>
	<!-- # Register Failed -->
	<!-- # String -->
	<P8307></P8307>
	<!-- # Off Hook -->
	<!-- # String  -->
	<P8308></P8308>
	<!-- # On Hook  -->
	<!-- # String  -->
	<P8309></P8309>
	<!-- # Incoming Call -->
	<!-- # String -->
	<P8310></P8310>
	<!-- # Outgoing Call -->
	<!-- # String -->
	<P8311></P8311>
	<!-- # Missed Call -->
	<!-- # String  -->
	<P8312></P8312>
	<!-- # Answered Call -->
	<!-- # String -->
	<P22171></P22171>
	<!-- # Rejected Call -->
	<!-- # String -->
	<P8315></P8315>
	<!-- # Forwarded Call -->
	<!-- # String -->
	<P22172></P22172>
	<!-- # Established Call -->
	<!-- # String -->
	<P8313></P8313>
	<!-- # Terminated Call -->
	<!-- # String -->
	<P8314></P8314>
	<!-- # Open DND -->
	<!-- # String -->
	<P8316></P8316>
	<!-- # Close DND -->
	<!-- # String  -->
	<P8317></P8317>
	<!-- # Open Forward -->
	<!-- # String -->
	<P8318></P8318>
	<!-- # Close Forward  -->
	<!-- # String -->
	<P8319></P8319>
	<!-- # Open Unconditional Forward -->
	<!-- # String -->
	<P22164></P22164>
	<!-- # Close Unconditional Forward -->
	<!-- # String -->
	<P22165></P22165>
	<!-- # Open Busy Forward -->
	<!-- # String -->
	<P22166></P22166>
	<!-- # Close Busy Forward -->
	<!-- # String -->
	<P22167></P22167>
	<!-- # Open No Answer Forward -->
	<!-- # String -->
	<P22168></P22168>
	<!-- # Close No Answer Forward -->
	<!-- # String -->
	<P22169></P22169>
	<!-- # Blind Transfer -->
	<!-- # String -->
	<P8320></P8320>
	<!-- # Attended Transfer -->
	<!-- # String -->
	<P8321></P8321>
	<!-- # Hold Call -->
	<!-- # String -->
	<P8324></P8324>
	<!-- # Unhold Call -->
	<!-- # String -->
	<P8325></P8325>
	<!-- # Open Syslog -->
	<!-- # String -->
	<P8330></P8330>
	<!-- # Close Syslog -->
	<!-- # String -->
	<P8331></P8331>
	<!-- # IP Change -->
	<!-- # String -->
	<P22170></P22170>
	<!-- # Auto-Provision Finish -->
	<!-- # String -->
	<P8332></P8332>
	<!-- ##  Maintenance/TR-069 -->
	<!-- # ACS URL -->
	<!-- # String -->
	<P4503></P4503>
	<!-- # TR-069 Username -->
	<!-- # String -->
	<P4504></P4504>
	<!-- # TR-069 Password -->
	<!-- # String -->
	<P4505></P4505>
	<!-- # Periodic Inform Enable. 0 - No, 1 - Yes. Default is 0 -->
	<P4506>0</P4506>
	<!-- # Periodic Inform Interval -->
	<!-- # Number -->
	<P4507>86400</P4507>
	<!-- # Connection Request Username	 -->
	<P4511></P4511>
	<!-- # Connection Request Password	 -->
	<P4512></P4512>
	<!-- # Connection Request Port -->
	<!-- # Number -->
	<P4518>7547</P4518>
	<!-- # CPE SSL Certificate -->
	<P8220></P8220>
	<!-- # CPE SSL Private Key -->
	<P8221></P8221>
	<!-- # Randomized TR069 Startup. 0 - Disabled, 1 - Enabled. Default is 0 -->
	<P8487>0</P8487>
	<!-- ##  Maintenance/Security Settings/Security -->
	<!-- # Configuration Via Keypad Menu. 0 - Unrestricted, 1 - Basic settings only, 2 - Constraint mode, 3 - Locked mode. Default is 0 -->
	<P1357>0</P1357>
	<!-- # Enable STAR key Keypad locking. 0 - No, 1 - Yes. Default is 1 -->
	<P1382>0</P1382>
	<!-- # Keypad Lock Type. 0 - Full, 1 - Functional. Default is 0 -->
	<P8383>0</P8383>
	<!-- # Password to lock/unlock (0-9 only) -->
	<!-- # Number -->
	<P1383></P1383>
	<!-- # Emergency Numbers -->
	<!-- # String -->
	<P8385></P8385>
	<!-- # Keypad Lock Timer -->
	<!-- # Number: 0 - 3600 -->
	<P8384></P8384>
	<!-- # Validate Server Certificates. 0 - No, 1 - Yes. Default is 0 -->
	<P8463>0</P8463>
	<!-- # SIP TLS Certificate -->
	<!-- #P280 = -->
	<!-- # SIP TLS Private Key -->
	<!-- #P279 = -->
	<!-- # SIP TLS Private Key Password -->
	<P281>s1pphone</P281>
	<!-- # Web Access Mode. 0 - HTTPS, 1 - HTTP, 2 - Disabled. Default is 1 -->
	<P1650>1</P1650>
	<!-- # Enable User Web Access. 0 - Disabled, 1 - Enabled. Default is 1 -->
	<P8469>1</P8469>
	<!-- # HTTP Web Port. Default is 80 -->
	<!-- # Number: 60 - 65535 -->
	<P22120>80</P22120>
	<!-- # HTTPS Web Port. Default is 443 -->
	<P22121>443</P22121>
	<!-- # Disable SSH. 0 - No, 1 - Yes. Default is 0 -->
	<P276>0</P276>
	<!-- # Web/Keypad/Restrict mode Lockout Duration (0-60 minutes). Default is 5 -->
	<!-- # Number: 0-60 -->
	<P1683>5</P1683>
	<!-- # Web Session Timeout. Default is 10. -->
	<!-- # Number: 2-60 -->
	<P28116>10</P28116>
	<!-- # Web Access Attempt Limit. Default is 5. -->
	<!-- # Number: 1-10 -->
	<P28117>5</P28117>
	<!-- ##  Maintenance/Security Settings/Trusted CA Certificate -->
	<!-- # Trusted CA Certificate -->
	<!-- # String -->
	<P8433></P8433>
	<P8434></P8434>
	<P8435></P8435>
	<P8436></P8436>
	<P8437></P8437>
	<P8438></P8438>
	<!-- # Load CA Certificates. 0 - Default Certificates, 1 - Custom Certificates, 2- All Certificates. Default is 2 -->
	<P8502>2</P8502>
	<!-- ##  Phonebook/Phonebook Management -->
	<!-- # Enable Phonebook XML Download. # 0 - No, 1 - YES, HTTP, 2 - YES, TFTP, 3 - Yes, HTTPS. Default is 0 -->
	<P330>1</P330>
	<!-- # HTTP/HTTPS User name -->
	<!-- # String -->
	<P6713></P6713>
	<!-- # HTTP/HTTPS Password -->
	<!-- # String -->
	<P6714></P6714>
	<!-- # Phonebook XML Server Path -->
	<!-- # This is a string of up to 256 characters that should contain a path to the XML file. It MUST be in the host/path format. -->
	<!-- # For example: directory.grandstream.com/engineering -->
	<!-- # String -->
	<P331>https://demo.example.com/phonebook.php?pb=EdRbklpGk</P331>
	<!-- # Phonebook Download Interval (in minutes) -->
	<!-- # Valid value range is 5-720. Default is 0 for disabled -->
	<!-- # Number: 0, 5-720;  -->
	<P332>0</P332>
	<!-- # Remove Manually-edited entries on Download. 0 - No, 1 - Yes. Default is 1 -->
	<P333>1</P333>
	<!-- # Import Group Method. 0 - Replace, 1 - Append. Default is 0 -->
	<P8462>0</P8462>
	<!-- # Sort Phonebook by. 0 - Last Name. 1 - First Name. Default is 0 -->
	<P2914>0</P2914>
	<!-- # Phonebook Key Function. 0 - Default, 1 - LDAP Search, 2 - Local Phonebook, 3 - Local Group, 4 - Broadsoft Phonebook. -->
	<!-- # Number: 0, 1, 2, 3, 4. -->
	<P1526>0</P1526>
	<!-- ##  Phonebook/LDAP -->
	<!-- # LDAP Directory -->
	<!-- # LDAP Protocol. 0 - LDAP, 1 - LDAPS. Default is 0. -->
	<P8370>0</P8370>
	<!-- # LDAP Server Address, up to 256 characters can be used. It can be IP address or Domain name -->
	<!-- # String -->
	<P8020></P8020>
	<!-- # LDAP Server Port. Default is 389. -->
	<!-- # Number: 1 - 65535 -->
	<P8021>389</P8021>
	<!-- # Base. The LDAP search base refers to the location in the directory where the search is requested to begin -->
	<!-- # Example 1: dc=grandstream,dc=com -->
	<!-- # value i 2: ou=Boston, dc=grandstream,dc=com -->
	<!-- # String -->
	<P8022></P8022>
	<!-- # User name. The bind "Username" for querying LDAP servers. Some LDAP servers allow anonymous binds in which case the setting can be left blank -->
	<!-- # String -->
	<P8023></P8023>
	<!-- # Password. The bind "Password" for querying LDAP servers. And the field can be left blank if the LDAP server allows anonymous binds -->
	<!-- # String -->
	<P8024></P8024>
	<!-- # LDAP Number Filter -->
	<!-- # LDAP name filter is the filter used for name look ups. Please refer to usermanual for examples -->
	<!-- # String -->
	<P8025></P8025>
	<!-- # LDAP Name Filter -->
	<!-- # String -->
	<P8026></P8026>
	<!-- # LDAP Version. Protocol version for the phone when send the bind requests -->
	<!-- # 2 - version 2, 3 - version 3. Default is 3 -->
	<P8027>3</P8027>
	<!-- # LDAP Name Attributes. This setting specifies the "name" attributes of each record which are returned in the LDAP search result -->
	<!-- # The setting allows the users to configure multiple space separated name attributes -->
	<!-- # String -->
	<P8028></P8028>
	<!-- # LDAP Number Attributes. This setting specifies the b�numberb� attributes of each record which are returned in the LDAP search result -->
	<!-- # The setting allows the users to configure multiple space separated number attributes -->
	<!-- # String -->
	<P8029></P8029>
	<!-- # LDAP Display Name. The entry information to be shown on phone LCD. Grandstream phones will display up to 3 fields -->
	<!-- # String -->
	<P8030></P8030>
	<!-- # Max Hits. The setting specifies the maximum number of results to be returned by the LDAP server -->
	<!-- # If the value is set to 0, server will return all search results. Default is 50 -->
	<!-- # Number: 0 - 32000 -->
	<P8031>50</P8031>
	<!-- # Search Timeout (in seconds). Default is 30 -->
	<!-- # The setting specifies how long the server should process the request and client waits for server to return -->
	<!-- # Number: 0 - 180 -->
	<P8032>30</P8032>
	<!-- # Sort Results. This setting is used for sorting searching result. 0 - no, 1 - yes. Default is 0 -->
	<P8033>0</P8033>
	<!-- # LDAP Lookup -->
	<!-- # Incoming calls. 0 - No, 1 - Yes. Default is 0 -->
	<P8035>0</P8035>
	<!-- # Outgoing calls. 0 - No, 1 - Yes. Default is 0 -->
	<P8034>0</P8034>
	<!-- # Lookup Display Name -->
	<!-- # String -->
	<P8036></P8036>
	<!-- ##  Settings/General Settings -->
	<!-- # Local RTP port. Default is 5004 -->
	<!-- # Number: 1024 - 65535. Must be even number -->
	<P39>5004</P39>
	<!-- # Local RTP port range -->
	<!-- # Number: 48 - 10000. Default is 200. -->
	<P29610>200</P29610>
	<!-- # Use Random Port. 0 - No, 1 - Yes. Default is 0 -->
	<P78>0</P78>
	<!-- # Keep-alive interval (in seconds). Default is 20 -->
	<!-- # Number: 10 - 160 -->
	<P84>20</P84>
	<!-- # Use NAT IP. This will enable our SIP client to use this IP in the SIP/SDP message. Example 64.3.153.50 -->
	<!-- # String: a-z, A-Z, 0-9, ".", ":" -->
	<P101></P101>
	<!-- # STUN server -->
	<!-- # String -->
	<P76></P76>
	<!-- # Public Mode. 0 - No. 1 - Yes. Default is 0 -->
	<P1345>0</P1345>
	<!-- # Enable Fix For RTP Timestamp Jump -->
	<P8389>0</P8389>
	<!-- # Test Password Strength. Default is 0. -->
	<!-- # Number: 0, 1. 0 - No, 1 - Yes.  -->
	<P8468>0</P8468>
	<!-- # DNS Cache Refresh Time, in minutes. Default is 30 -->
	<!-- # Number: 5 - 1440 -->
	<P4208></P4208>
	<!-- ##  Settings/Call Features -->
	<!-- # Onhook Dial Barging. Default is 1 -->
	<!-- # Number: 0 - Disabled, 1 - Enabled. -->
	<P8397>1</P8397>
	<!-- # Off-hook Auto Dial -->
	<!-- # String -->
	<P71></P71>
	<!-- # Off-hook Auto Dial Delay -->
	<!-- # Number: 0 - 30 -->
	<P8388>0</P8388>
	<!-- # Off-hook timeout (in seconds). Default is 30 -->
	<!-- # Number: 10 - 60 -->
	<P1485>30</P1485>
	<!-- # Enable Live DialPad. -->
	<P8350>0</P8350>
	<!-- # Live DialPad Expire Time -->
	<!-- # Number: 2 - 15. Default is 5. -->
	<P8351>5</P8351>
	<!-- # Busy Tone Expiration -->
	<!-- # Number: 0 - 60. Default is 30. -->
	<P8443>30</P8443>
	<!-- # Enable Automatic Redial -->
	<P8353>0</P8353>
	<!-- # Automatic Redial Times -->
	<!-- # Number: 1 - 100. Default is 10. -->
	<P8354>10</P8354>
	<!-- # Automatic Redial Interval -->
	<!-- # Number: 1 - 360. Default is 20. -->
	<P8355>20</P8355>
	<!-- # Intercom Key Mode. 0 - Intercom, 1 - Multicast Paging. Default is 0. -->
	<P22123>0</P22123>
	<!-- # Intercom User ID -->
	<!-- # String -->
	<P1303></P1303>
	<!-- # Intercom Multicast Paging Address -->
	<!-- # String -->
	<P22124></P22124>
	<!-- # Intercom Multicast Paging Label -->
	<!-- # String -->
	<P22125></P22125>
	<!-- # Bypass Dial Plan Through Call History and Directories -->
	<!-- # Number: 0,1. Default is 0 -->
	<P6758>0</P6758>
	<!-- # Disable Call Waiting. 0 - No, 1 - Yes. Default is 0 -->
	<P91>0</P91>
	<!-- # Disable Call-Waiting Tone. 0 - No, 1 - Yes. Default is 0 -->
	<P186>0</P186>
	<!-- # Ring For Call Waiting -->
	<P22102>0</P22102>
	<!-- # Disable Busy Tone on Remote Disconnect. 0 - No, 1 - Yes. Default is 0 -->
	<P6762>0</P6762>
	<!-- # Disable Direct IP Call. 0 - No, 1 - Yes. Default is 0 -->
	<P1310>0</P1310>
	<!-- # Use Quick IP Call mode. 0 - No, 1 - Yes. Default is 0 -->
	<P184>0</P184>
	<!-- # Disable Conference. 0 - No, 1 - Yes. Default is 0 -->
	<P1311>0</P1311>
	<!-- # Disable in-call DTMF Display. 0 - No, 1 - Yes. Default is 0 -->
	<P338>0</P338>
	<!-- # Enable Sending DTMF via Specific MPKs. 0 - No, 1 - Yes. Default is 0 -->
	<P1339>0</P1339>
	<!-- # Mute Key Functions While Idle. 0 - DND, 1 - Idle Mute, 2 - Disabled. Default is 0 -->
	<P1565>0</P1565>
	<!-- # Disable Transfer. 0 - No, 1 - Yes. Defauls is 0 -->
	<P1341>0</P1341>
	<!-- # In-call Dial Number on pressing transfer key -->
	<!-- # String -->
	<P1525></P1525>
	<!-- # Attended Transfer Mode -->
	<!-- # Number: 0 - Static, 1 - Dynamic. Default is 0. -->
	<P1376></P1376>
	<!-- # Do not escape '#' as 23% in SIP URL. 0 - No, 1 - Yes. Default is 0 -->
	<P1406>0</P1406>
	<!-- # Use Pound # For Redial. 0 - No, 1 - Yes. Default is 1 -->
	<P8504>1</P8504>
	<!-- # Click-To-Dial Feature. 0 - No, 1 - Yes. Default is 0 -->
	<P1561>0</P1561>
	<!-- # Call History Flash Writing: 0 means this option is disabled -->
	<!-- # Write Timeout, 30-3600, in seconds, default is 300 -->
	<P1433>300</P1433>
	<!-- # Max Unsaved Log, 0-500, default is 200 -->
	<!-- # Number: 0-500 -->
	<P1434>200</P1434>
	<!-- # User-Agent Prefix -->
	<!-- # String -->
	<P8358></P8358>
	<!-- # Predictive Dialing Feature. 0 - disabled, 1 - enabled. Default is 1 -->
	<P22126>1</P22126>
	<!-- # Disable Hook Switch -->
	<!-- # Number: 0 - No, 1 - Yes, 2 - For Answering Call. Default is 0. -->
	<P6763>0</P6763>
	<!-- # Show SIP Error Response. 0 - No, 1 - Yes. Default is 1. -->
	<P8376>1</P8376>
	<!-- # Auto Answer Delay. Default is 0. -->
	<!-- # Number: 0 - 4. -->
	<P8486>0</P8486>
	<!-- # Enable Enhanced Acoustic Echo Canceller. 0 - No, 1 - Yes. Default is 1 -->
	<P22175>1</P22175>
	<!-- # Show On Hold Duration. 0 - No, 1 - Yes. Default is 0 -->
	<P8503>0</P8503>
	<!-- # Hide/Disable Reject Key. 0 - No, 1 - Yes. Default is 0 -->
	<P8511>0</P8511>
	<!-- # Enable Diversion Information Display. 0 - No, 1 - Yes. Default is 1 -->
	<P22237>1</P22237>
	<!-- # Blink message LED on ringing - GXP1610 only -->
	<!-- # Blink message LED on ringing. 0 - No, 1 - Yes. Default is 0 -->
	<P1696>0</P1696>
	<!-- ##  Settings/Multicast Paging -->
	<!-- # Paging Barge. 0 - Disable, 1 - priority 1, 2 - priority 2, 3 - priority 3,  -->
	<!-- # 4 - priority 4, 5 - priority 5, 6 - priority 6, 7 - priority 7, 8 - priority 8, -->
	<!-- # 9 - priority 9, 10 - priority 10. Default is 0. -->
	<!-- # Number: 0 - 10 -->
	<P1566>0</P1566>
	<!-- # Paging Priority Active. 0 - Disabled, 1 - Enabled -->
	<P1567>0</P1567>
	<!-- # Multicast Paging Codec. 0 - PCMU, 2 - G.726-32, 4 - G.723.1, 8 - PCMA, 9 - G.722, 18 - G.729A/B -->
	<!-- # Number: 0, 2, 4, 8, 9, 18 -->
	<P1568>0</P1568>
	<!-- # Multicast Channel Number. 0 - 50. Default is 0 -->
	<!-- # Number -->
	<P8454>0</P8454>
	<!-- # Multicast Sender ID -->
	<!-- # String -->
	<P8455></P8455>
	<!-- ### Multicast Listening ###  -->
	<!-- # Priority 1 -->
	<!-- # Listening Address -->
	<!-- # String -->
	<P1569></P1569>
	<!-- # Label -->
	<!-- # String -->
	<P1570></P1570>
	<!-- # Priority 2 -->
	<!-- # String -->
	<P1571></P1571>
	<!-- # Label -->
	<!-- # String -->
	<P1572></P1572>
	<!-- # Priority 3 -->
	<!-- # String -->
	<P1573></P1573>
	<!-- # Label -->
	<!-- # String -->
	<P1574></P1574>
	<!-- # Priority 4 -->
	<!-- # String -->
	<P1575></P1575>
	<!-- # Label -->
	<!-- # String -->
	<P1576></P1576>
	<!-- # Priority 5 -->
	<!-- # String -->
	<P1577></P1577>
	<!-- # Label -->
	<!-- # String -->
	<P1578></P1578>
	<!-- # Priority 6 -->
	<!-- # String -->
	<P1579></P1579>
	<!-- # Label -->
	<!-- # String -->
	<P1580></P1580>
	<!-- # Priority 7 -->
	<!-- # String -->
	<P1581></P1581>
	<!-- # Label -->
	<!-- # String -->
	<P1582></P1582>
	<!-- # Priority 8 -->
	<!-- # String -->
	<P1583></P1583>
	<!-- # Label -->
	<!-- # String -->
	<P1584></P1584>
	<!-- # Priority 9 -->
	<!-- # String -->
	<P1585></P1585>
	<!-- # Label -->
	<!-- # String -->
	<P1586></P1586>
	<!-- # Priority 10 -->
	<!-- # String -->
	<P1587></P1587>
	<!-- # Label -->
	<!-- # String -->
	<P1588></P1588>
	<!-- ##  Settings/Preferences/Audio Control -->
	<!-- # HEADSET Key Mode. 0 = Default Mode, 1 = Toggle Headset/Speaker. Default is 0 -->
	<P1312>0</P1312>
	<!-- # Headset Type. 0 - Normal, 1 - Plantronics EHS. Default is 0 -->
	<P1487>0</P1487>
	<!-- # Always Ring Speaker. 0 - No, 1 - Yes. Default is 0 -->
	<P1439>0</P1439>
	<!-- # Enable Group Listening. 0 - No, 1 - Yes. Default is 0 -->
	<P22100>0</P22100>
	<!-- # Grouop Listen with Speaker. 0 - No, 1 - Yes. Default is 0 -->
	<P22163>0</P22163>
	<!-- # Headset TX gain(db). 1 - -6, 0 - 0, 2 - +6. Default is 0 -->
	<P1301>0</P1301>
	<!-- # Headset RX gain(db). 1 - -6, 0 - 0, 2 - +6. Default is 0 -->
	<P1302>0</P1302>
	<!-- # Handset TX gain(db). 1 - -6, 0 - 0, 2 - +6. Default is 0 -->
	<P1464>0</P1464>
	<!-- ##  Settings/Preferences/Date and Time -->
	<!-- # NTP Server -->
	<!-- # String -->
	<P30>pool.ntp.org</P30>
	<!-- # Allow DHCP Option 42 to override NTP server. 0 - No, 1 - Yes. Default is 1 -->
	<!-- # When set to Yes(1), it will override the configured NTP server -->
	<P144>1</P144>
	<!-- # Time Zone -->
	<!-- # Web GUI Option										P Value -->
	<!-- # Automatic												auto -->
	<!-- # GMT-12:00 (International Date Line West)				TZA+12 -->
	<!-- # GMT-11:00 (Midway Island, Samoa) 						TZB+11 -->
	<!-- # GMT-10:00 (US Hawaiian Time) 							HAW10 -->
	<!-- # GMT-9:00 (US Alaska Time) 							AKST9AKDT -->
	<!-- # GMT-8:00 (US Pacific Time, Los Angeles)				PST8PDT -->
	<!-- # GMT-08:00 (Baja California)							PST8PDT,M3.2.0,M11.1.0 -->
	<!-- # GMT-07:00 (US Mountain Time, Denver) 					MST7MDT -->
	<!-- # GMT-07:00 (Mountain Time (Arizona, no DST)) 			MST7 -->
	<!-- # GMT-07:00 (Chihuahua, La Paz, Mazatlan)				MST7MDT,M4.1.0,M10.5.0   -->
	<!-- # GMT-06:00 (Central Time) 								CST6CDT -->
	<!-- # GMT-06:00 (Central America) 							CST+6 -->
	<!-- # GMT-06:00 (Guadalajara, Mexico City, Monterrey)		CST6CDT,M4.1.0,M10.5.0 -->
	<!-- # GMT-05:00 (Eastern Time)								EST5EDT -->
	<!-- # GMT-05:00 (Eastern Time without daylight saving) 		EST5 -->
	<!-- # GMT-04:30 (Caracas) 									TZf+4:30 -->
	<!-- # GMT-04:00 (Atlantic Time) 							AST4ADT -->
	<!-- # GMT-04:00 (Atlantic Time (New Brunswick)) 			AST4ADT,M3.2.0,M11.1.0 -->
	<!-- # GMT-03:30 (Newfoundland Time)							NST+3:30NDT+2:30,M3.2.0/00:01:00,M11.1.0/00:01:00 -->
	<!-- # GMT-03:00 (Greenland) 								TZK+3 -->
	<!-- # GMT-03:00 (Brazil, Sao Paulo) 						BRST+3BRDT+2,M10.3.0,M2.3.0 -->
	<!-- # GMT-02:00 (Argentina) 								UTC+3  -->
	<!-- # GMT-02:00 (Mid-Atlantic) 								TZL+2 -->
	<!-- # GMT-01:00 (Azores, Cape Verdi Is.) 					TZM+1 -->
	<!-- # GMT (Edinburgh, Casablanca, Monrovia) 				TZN+0 -->
	<!-- # GMT (London, Great Britain) 							GMT+0BST-1,M3.5.0/01:00:00,M10.5.0/02:00:00 -->
	<!-- # GMT (Lisbon, Portugal) 								WET-0WEST-1,M3.5.0/01:00:00,M10.5.0/02:00:00 -->
	<!-- # GMT (Dublin, Ireland) 								GMT+0IST-1,M3.5.0/01:00:00,M10.5.0/02:00:00 -->
	<!-- # GMT+01:00 (Paris, Vienna, Warsaw, Roma, Madrid, Prague, Berlin, Budapest, Amsterdam, Belgium)   CET-1CEST-2,M3.5.0/02:00:00,M10.5.0/03:00:00 -->
	<!-- # GMT+02:00 (Israel, Cairo, Athens, Istanbul, Buchrest) TZP-2 -->
	<!-- # GMT+02:00 (Helsinki, Athens, Tallinn) 				EET-2EEST-3,M3.5.0/03:00:00,M10.5.0/04:00:00 -->
	<!-- # GMT+02:00 (Kyiv, Ukraine) 							EET-2EEST,M3.5.0/3,M10.5.0/4  -->
	<!-- # GMT+03:00 (Kuwait, Baghdad, Tehran, Nairobi) 			TZQ-3 -->
	<!-- # GMT+03:00 (Moscow, Russia) 							MSK-3MSD,M3.5.0/2,M10.5.0/3 -->
	<!-- # GMT+03:00 (St.Petersburg, Russia) 					MST-3MDT,M3.5.0/2,M10.5.0/3 -->
	<!-- # GMT+04:00 (Abu Dhabi, Baku) 							TZR-4 -->
	<!-- # GMT+05:00 (Islamabad, Ekaterinburg, Karachi, Tashkent)TZS-5 -->
	<!-- # GMT+05:30 (Chennai, New Delhi, Mumbai) 				TZT-5:30 -->
	<!-- # GMT+05:45 (Kathmandu) 								TZU-5:45 -->
	<!-- # GMT+06:00 (Almaty, Astana, Dhaka, Novosibirsk) 		TZV-6 -->
	<!-- # GMT+06:30 (Rangoon) 									TZW-6:30 -->
	<!-- # GMT+07:00 (Bankok, Hanoi, Krasnoyarsk) 				TZX-7 -->
	<!-- # GMT+07:00 (Jakarta) 									WIB-7 -->
	<!-- # GMT+08:00 (Beijing, Taipei, Kuala Lumpur, Irkutsk) 	TZY-8 -->
	<!-- # GMT+08:00 (Singapore) 								SGT-8 -->
	<!-- # GMT+08:00 (Ulaanbaatar, Mongolia) 					ULAT-8 -->
	<!-- # GMT+08:00 (Perth) 									WST-8 -->
	<!-- # GMT+09:00 (Japan, Korea, Yakutsk) 					TZZ-9 -->
	<!-- # GMT+09:30 (Adelaide) 									CST-9:30CDT-10:30,M10.5.0/02:00:00,M3.5.0/03:00:00 -->
	<!-- # GMT+09:30 (Darwin) 									CST-9:30  -->
	<!-- # GMT+10:00 (Guam) 										TZb-10 -->
	<!-- # GMT+10:00 (Hobart) 									EST-10EDT-11,M10.1.0/02:00:00,M3.5.0/03:00:00 -->
	<!-- # GMT+10:00 (Sydney, Melbourne, Canberra) 				EST-10EDT-11,M10.5.0/02:00:00,M3.5.0/03:00:00 -->
	<!-- # GMT+10:00 (Brisbane) 									EST-10 -->
	<!-- # GMT+11:00 (Magadan, Solomon Is., New Caledonia) 		TZc-11 -->
	<!-- # GMT+12:00 (Auckland, Wellington) 						NZST-12NZDT-13,M10.1.0/02:00:00,M3.3.0/03:00:00 -->
	<!-- # GMT+12:00 (Fiji) 										TZd-12 -->
	<!-- # GMT+13:00 (Nuku'alofa) 								TZe-13 -->
	<!-- # Self-Defined Time Zone								customize -->
	<!-- # String -->
	<P64>TZX-7</P64>
	<!-- # Allow DHCP Option 2 to override Time Zone setting. 0 - No, 1 - Yes. Default is 1 -->
	<!-- # When set to Yes(1), it will override the configured Time Zone setting if available  -->
	<P143>1</P143>
	<!-- # Self Defined Time zone. Max length allowed is 64 characters -->
	<!-- # String -->
	<P246>MTZ+6MDT+5,M4.1.0,M11.1.0</P246>
	<!-- # Date Display Format -->
	<!-- # 0: yyyy-mm-dd      eg. 2011-10-31 -->
	<!-- # 1: mm-dd-yyyy      eg. 10-31-2011 -->
	<!-- # 2: dd-mm-yyyy      eg. 31-10-2011 -->
	<!-- # 3: dddd, MMMM dd   eg. Monday, October 31 -->
	<!-- # 4: MMMM dd, dddd   eg. October 31, Monday -->
	<P102>0</P102>
	<!-- # Time Display Format. 0 - 12 Hour, 1 - 24 Hour -->
	<P122>24Hour</P122>
	<!-- ##  Settings/Preferences/LCD Display -->
	<!-- # Backlight Brightness: Active.  Valid range is 0 - 8.  GXP1620/1625/1628/1630 only -->
	<!-- # Active. Default is 6. -->
	<!-- # Number: 0 - 8 -->
	<P334>6</P334>
	<!-- # Backlight Brightness: Idle. Valid range is 0 - 8. GXP1620/1625/1628/1630 only -->
	<!-- # Default is 2. -->
	<P335>2</P335>
	<!-- # Active Backlight Timeout. Default is 1 -->
	<!-- # Number: 1 - 90 -->
	<P8356>1</P8356>
	<!-- # LCD Contrast. Default is 3 -->
	<!-- # Number: 1 - 5 -->
	<P6771>3</P6771>
	<!-- # Disable Missed Call Backlight. 0 - No, 1 - Yes. Default is 0 -->
	<P351>0</P351>
	<!-- # Wide Idle Screen View. 0 - No, 1 - Yes. Default is 0 -->
	<P8346>0</P8346>
	<!-- # Caller ID Display Mode. 0 - Dynamic, 1 - Static. Default is 0 -->
	<P8473>0</P8473>
	<!-- # Settings/Preferences/LED control -->
	<!-- # Disable VM/MSG power light flash -->
	<P8371>0</P8371>
	<!-- ##  Settings/Preferences/Ringtone -->
	<!-- ### Call Progress Tones ### -->
	<!-- # Syntax: f1=val,f2=val[,c=on1/off1[-on2/off2[-on3/off3]]];  -->
	<!-- # (Frequencies are in Hz and cadence on and off are in 10ms)  -->
	<!-- # System Ring Tone -->
	<!-- # String -->
	<P345>f1=440,f2=480,c=200/400;</P345>
	<!-- # Dial Tone -->
	<!-- # String -->
	<P343>f1=350,f2=440;</P343>
	<!-- # Second Dial Tone -->
	<!-- # String -->
	<P2909>f1=350,f2=440;</P2909>
	<!-- # Message Waiting Tone -->
	<!-- # String -->
	<P344>f1=350,f2=440,c=10/10;</P344>
	<!-- # Ring Back Tone -->
	<!-- # String -->
	<P346>f1=440,f2=480,c=200/400;</P346>
	<!-- # Call-Waiting Tone -->
	<!-- # String -->
	<P347>f1=440,f2=440,c=25/525;</P347>
	<!-- # Call-Waiting Tone Gain. 0 - Low, 1 - Medium, 2 - High. Default is 0 -->
	<P1555>0</P1555>
	<!-- # Busy Tone -->
	<!-- # String -->
	<P348>f1=480,f2=620,c=50/50;</P348>
	<!-- # Reorder Tone -->
	<!-- # String -->
	<P349>f1=480,f2=620,c=25/25;</P349>
	<!-- # Speaker Ring Volume. Default is 7 -->
	<P8352>7</P8352>
	<!-- # Notification Tone Volume -->
	<!-- # Number: 0 - 7. Default is 4. -->
	<P8399>4</P8399>
	<!-- # Lock Speaker Volume -->
	<P8392>0</P8392>
	<!-- # Default Ringtone -->
	<!-- # 0 - System Ringtone, 1 - Custom Ringtone 1, 2 - Custom Ringtone 2, 3 - Custom Ringtone 3, 4 - Silent, 6 - Custom Ringtone 4, 7 - Custom Ringtone 5, 8 - Custom Ringtone 6, 9 - Custom Ringtone 7, 10 - Custom Ringtone 8, 11 - Custom Ringtone 9, 12 - Custom Ringtone 10 -->
	<!-- # Number: 0, 1, 2, 3, 4, 6, 7, 8, 9, 10, 11, 12. Default is 0 -->
	<P8398>0</P8398>
	<!-- # Total Number of Custom Ringtone Update Default is 3 -->
	<!-- # Number: 1 - 10 -->
	<P8509>3</P8509>
	<!-- ##  Settings/Web Service -->
	<!-- # Use Auto Location Service. 0 - No, 1 - Yes. Default is 1 -->
	<P8338>1</P8338>
	<!-- ##  Settings/XML Applications -->
	<!-- # Idle Screen XML Download -->
	<!-- # 0 - disabled, 1 - enabled:HTTP, 2 - enabled:TFTP, 3 - enabled:HTTPS. Default is 0 -->
	<P340>0</P340>
	<!-- # Download Screen XML At Boot-up. 0 - No, 1 - Yes. Default is 0 -->
	<P1349>0</P1349>
	<!-- # Use Custom File Name. 0 - No, 1 - Yes. Default is 0 -->
	<P1343>0</P1343>
	<!-- # Idle Screen XML Server Path -->
	<!-- # This is a string of up to 256 characters that should contain a path to the XML file -->
	<!-- # It MUST be in the host/path format. For example: directory.grandstream.com/engineering -->
	<!-- # String -->
	<P341></P341>
	<!-- # Server Path -->
	<!-- # String -->
	<P337></P337>
	<!-- # Softkey Label -->
	<!-- # String -->
	<P352></P352>
	<!-- ##  Settings/Programmable Keys/Multi-Purpose Keys Settings -->
	<!-- # Transfer Mode via VPK. 0 - Blind Transfer, 1 - Attended Transfer, 2 - New Call. Default is 0 -->
	<P8390>0</P8390>
	<!-- # Enable transfer via non-Transfer MPK. 0 - No, 1 - Yes. Default is 0 -->
	<P22162>0</P22162>
	<!-- ##  Settings/Programmable Keys/Programmable Keys -->
	<!-- # Key Mode 14 - Speed dial via active account, for GXP1620/1625/1628/1630 only -->
	<!-- # Key Mode 11 - BLF, 12 - Presence Watcher, 13 - Eventlist BLF, 19 - Call Park, 26 - Monitored Call Park, for GXP1628/1630 only -->
	<!-- # Line Keys -->
	<!-- # Line Key 1 -->
	<!-- # Key Mode. Default is 0 -->
	<!-- # 0 - Line, 1 - Shared Line, 10 - Speed Dial, 11 - BLF, 12 - Presence Watcher, 13 - Eventlist BLF, 14 - Speed Dial via active account -->
	<!-- # 15 - Dial DTMF, 16 - Voicemail, 17 - Call Return, 18 - Transfer, 19 - Call Park, 26 - Monitored Call Park, 20 - Intercom  -->
	<!-- # 21 - LDAP Search, 23 - Multicast Paging, 27 - GDS OpenDoor, 28 - Provision -->
	<!-- # Number: 0, 1, 10-21, 23, 26-28 -->
	<P1363>0</P1363>
	<!-- # Account. 0 - Account 1, 1 - Account 2, 2 - Account 3 -->
	<P1364>0</P1364>
	<!-- # Description. Max length allowed is 32 characters. -->
	<!-- # String -->
	<P1465></P1465>
	<!-- # Value. Max length allowed is 64 characters. -->
	<!-- # String -->
	<P1466></P1466>
	<!-- # Line Key 2 -->
	<P1365>0</P1365>
	<P1366>0</P1366>
	<!-- # String -->
	<P1467></P1467>
	<!-- # String -->
	<P1468></P1468>
	<!-- # Line Key 3 -->
	<P1367>0</P1367>
	<P1368>2</P1368>
	<!-- # String -->
	<P1469></P1469>
	<!-- # String -->
	<P1470></P1470>
	<!-- # Customizable Softkey -->
	<!-- # Softkey 1 -->
	<!-- # Mode: 0 - Default, 10 - Speed Dial, 14 - Speed Dial via Active Account, 16 - Voice Mail, 17 - Call Return, 20 - Intercom, 21 - LDAP Search. Default is 0. -->
	<!-- # Number -->
	<P2987>0</P2987>
	<!-- # Account: 0 - Account 1, 1 - Account 2, 2 - Account 3. Default is 0 -->
	<!-- # Number -->
	<P2988>0</P2988>
	<!-- # Description -->
	<!-- # String -->
	<P2989></P2989>
	<!-- # Value -->
	<!-- # String -->
	<P2990></P2990>
	<!-- ##    Settings/Broadsoft/Broadsoft Directories -->
	<!-- # XSI -->
	<!-- # Server Address -->
	<!-- # String -->
	<P1591></P1591>
	<!-- # Port -->
	<!-- # Number -->
	<P1592></P1592>
	<!-- # XSI Actions Path -->
	<!-- # String -->
	<P2937></P2937>
	<!-- # Broadsoft Contact Download Interval. 0 - Disabled. Default is 0 -->
	<!-- # Number: 0, 5-720 -->
	<P8362>0</P8362>
	<!-- # XSI Authentication Type. 0 - Login Credentials, 1 - SIP, 2 - Account 1, 3 - Account 2, 4 - Account 3. Default is 0 -->
	<P22054>0</P22054>
	<!-- # Login Credentials               -->
	<!-- # Login Username -->
	<!-- # String -->
	<P1593></P1593>
	<!-- # Login Password -->
	<!-- # String -->
	<P1594></P1594>
	<!-- # SIP Credentials               -->
	<!-- # SIP Username -->
	<!-- # String -->
	<P6772></P6772>
	<!-- # String -->
	<P22034></P22034>
	<!-- # SIP Password -->
	<!-- # String -->
	<P6773></P6773>
	<!-- # Sort Phonebook by. 0 - Last Name, 1 - First Name. Default is 0 -->
	<P22131>0</P22131>
	<!-- # Network Directories -->
	<!-- ### Group Directory ### -->
	<!-- # Disabled/Enabled. 0 - Disabled, 1 - Enabled. -->
	<P2971>0</P2971>
	<!-- # Name -->
	<!-- # String -->
	<P2972></P2972>
	<!-- ### Enterprise Directory ### -->
	<P2973>0</P2973>
	<!-- # Name -->
	<!-- # String -->
	<P2974></P2974>
	<!-- ### Group Common ### -->
	<P2975>0</P2975>
	<!-- # Name -->
	<!-- # String -->
	<P2976></P2976>
	<!-- ### Enterprise Common ### -->
	<P2977>0</P2977>
	<!-- # Name -->
	<!-- # String -->
	<P2978></P2978>
	<!-- ### Personal Directory ### -->
	<P2979>0</P2979>
	<!-- # Name -->
	<!-- # String -->
	<P2980></P2980>
	<!-- ### Missed Call Log ###  -->
	<P2981>0</P2981>
	<!-- # Name -->
	<!-- # String -->
	<P2982></P2982>
	<!-- ### Placed Call Log ###  -->
	<P2983>0</P2983>
	<!-- # Name -->
	<!-- # String -->
	<P2984></P2984>
	<!-- ### Received Call Log ###  -->
	<P2985>0</P2985>
	<!-- # Name.  -->
	<!-- # String -->
	<P2986></P2986>
	<!-- ##  Settings/External Service -->
	<!-- ##  Grandstream Door System -->
	<!-- ########## No.1 ########## -->
	<!-- # No.1 - Service Type -->
	<!-- # Number: -1 - None, 0 - GDS. Default is 0 -->
	<P32000>0</P32000>
	<!-- # No.1 - Account -->
	<!-- # Number: 0 - Account 1, 1 - Account 2, 2 - Account 3. Default is 0 -->
	<P32001>0</P32001>
	<!-- # No.1 - System Identification -->
	<!-- # String -->
	<P32002></P32002>
	<!-- # No.1 - System Number -->
	<!-- # String -->
	<P32003></P32003>
	<!-- # No.1 - Access Password -->
	<!-- # String -->
	<P32004></P32004>
	<!-- ########## No.2 ########## -->
	<!-- # No.2 - Service Type -->
	<P32005>0</P32005>
	<!-- # No.2 - Account -->
	<P32006>0</P32006>
	<!-- # No.2 - System Identification -->
	<!-- # String -->
	<P32007></P32007>
	<!-- # No.2 - System Number -->
	<!-- # String -->
	<P32008></P32008>
	<!-- # No.2 - Access Password -->
	<!-- # String -->
	<P32009></P32009>
	<!-- ########## No.3 ########## -->
	<!-- # No.3 - Service Type -->
	<P32010>0</P32010>
	<!-- # No.3 - Account -->
	<P32011>0</P32011>
	<!-- # No.3 - System Identification -->
	<!-- # String -->
	<P32012></P32012>
	<!-- # No.3 - System Number -->
	<!-- # String -->
	<P32013></P32013>
	<!-- # No.3 - Access Password -->
	<!-- # String -->
	<P32014></P32014>
	<!-- ########## No.4 ########## -->
	<!-- # No.4 - Service Type -->
	<P32015>0</P32015>
	<!-- # No.4 - Account -->
	<P32016>0</P32016>
	<!-- # No.4 - System Identification -->
	<!-- # String -->
	<P32017></P32017>
	<!-- # No.4 - System Number -->
	<!-- # String -->
	<P32018></P32018>
	<!-- # No.4 - Access Password -->
	<!-- # String -->
	<P32019></P32019>
	<!-- ########## No.5 ########## -->
	<!-- # No.5 - Service Type -->
	<P32020>0</P32020>
	<!-- # No.5 - Account -->
	<P32021>0</P32021>
	<!-- # No.5 - System Identification -->
	<!-- # String -->
	<P32022></P32022>
	<!-- # No.5 - System Number -->
	<!-- # String -->
	<P32023></P32023>
	<!-- # No.5 - Access Password -->
	<!-- # String -->
	<P32024></P32024>
	<!-- ########## No.6 ########## -->
	<!-- # No.6 - Service Type -->
	<P32025>0</P32025>
	<!-- # No.6 - Account -->
	<P32026>0</P32026>
	<!-- # No.6 - System Identification -->
	<!-- # String -->
	<P32027></P32027>
	<!-- # No.6 - System Number -->
	<!-- # String -->
	<P32028></P32028>
	<!-- # No.6 - Access Password -->
	<!-- # String -->
	<P32029></P32029>
	<!-- ########## No.7 ########## -->
	<!-- # No.7 - Service Type -->
	<P32030>0</P32030>
	<!-- # No.7 - Account -->
	<P32031>0</P32031>
	<!-- # No.7 - System Identification -->
	<!-- # String -->
	<P32032></P32032>
	<!-- # No.7 - System Number -->
	<!-- # String -->
	<P32033></P32033>
	<!-- # No.7 - Access Password -->
	<!-- # String -->
	<P32034></P32034>
	<!-- ########## No.8 ########## -->
	<!-- # No.8 - Service Type -->
	<P32035>0</P32035>
	<!-- # No.8 - Account -->
	<P32036>0</P32036>
	<!-- # No.8 - System Identification -->
	<!-- # String -->
	<P32037></P32037>
	<!-- # No.8 - System Number -->
	<!-- # String -->
	<P32038></P32038>
	<!-- # No.8 - Access Password -->
	<!-- # String -->
	<P32039></P32039>
	<!-- ########## No.9 ########## -->
	<!-- # No.9 - Service Type -->
	<P32040>0</P32040>
	<!-- # No.9 - Account -->
	<P32041>0</P32041>
	<!-- # No.9 - System Identification -->
	<!-- # String -->
	<P32042></P32042>
	<!-- # No.9 - System Number -->
	<!-- # String -->
	<P32043></P32043>
	<!-- # No.9 - Access Password -->
	<!-- # String -->
	<P32044></P32044>
	<!-- ########## No.10 ########## -->
	<!-- # No.10 - Service Type -->
	<P32045>0</P32045>
	<!-- # No.10 - Account -->
	<P32046>0</P32046>
	<!-- # No.10 - System Identification -->
	<!-- # String -->
	<P32047></P32047>
	<!-- # No.10 - System Number -->
	<!-- # String -->
	<P32048></P32048>
	<!-- # No.10 - Access Password -->
	<!-- # String -->
	<P32049></P32049>
	</config>
</gs_provision>
