Phone after auto provision login
Hi guys trying to set up some yealinks - I have setup the phone provisioning - and when I click update now - it says grabbing info - logs me out then no username password will work - factory reset a few times but everytime just says username password is wrong.
You can see the default password in the “Provisioning Template” module, under the “GUI Settings” tab.
Thanks for that - looked everywhere but there.
Can log back in - but register is failing on the auto provision setup.
is there somewhere to check the logs as to why - migrating from 3cx and layout is different
You can check in the Phone GUI what data is missing in the account registration.
I bought the phone provision to make this easier - all the videos just auto provision and then they register.
Is that the server IP? Is it a local server? Is PJSIP running on port 5060?
yes its the server ip yes it local and yes pjsip 5060.
