I would appreciate if someone could provide some guidance on how to patch Asterisk 18.6.0 included in VitalPBX with patch from Patching Asterisk to support extra features for Cisco phones. I am experienced in compiling tarballs but never tried to patch something installed from RPMs. So far I was able to create a totally new and patched Asterisk but it seems it does not read VitalPBX’s Asterisk configuration files (/etc/asterisk).
If your patch generates a driver file(*.so), you can copy that file and install it on your VitalPBX(/usr/lib64/asterisk/modules/). Once the file is copied into the right directory, you have to restart Asterisk.
I tried this but nothing happens. Also tried to add the extra config lines as suggested by patch developer.
Anyway, I tried to compile the same version of asterisk that is included in VitalPBX manually. I succeeded but it seems it does not read its configuration from /etc/asterisk. Any idea why this happens?
