Hi VitalPBX & All Member Forum
When the call comes to ivr, the customer will be asked to enter the “CUST_ID” (DTMF) number
My question :
How to get the variable so that it can appear in the CRM_URL?
My question :
Hi ALl
Vitxy ‘4.0.1-3’ → March 30, 2023
Added → CRM URL: Static variables
How to use “Static variables” ? Can i get variable from diaplan asterisk?
Hi Sir,
At the moment, the only dynamic variables available are the ones that appear in the dropdown when “Use Dynamic Variable” is checked.
Static variables will have the static value that is configured when the settings are saved,
Hi @maynor
Thanks your response, any solution to get variable from asterisk dialplan and use that variable on popup CRM? That’s very important of integrated with crm
Hi!
You can do this by using custom contexts. In the link below, there’s an example of it.
