Passing P-Asserted-Identity from Softphone to Outbound Trunk From Header
Hi everyone,
I am trying to configure VitalPBX so that when a softphone sends an outbound INVITE containing a P-Asserted-Identity (PAI) header, VitalPBX reads this header and uses its value as the Caller ID in the From header sent to our outbound PJSIP trunk.
Current Scenario:
· Softphone sends an outbound INVITE with: P-Asserted-Identity: <sip:[email protected]>
· Goal: Extract the data and use it as the From header user when making the outbound call over the PJSIP trunk.
What was tested:
1. Set extension Dynamic External CID to YES.
2. Set trunk Trust ID Inbound to YES
Questions for the community:
· What is the recommended practice in VitalPBX to extract an incoming softphone PAI header and pass it to the outbound trunk From field?
Any examples or best-practice recommendations would be greatly appreciated!
Please try by enabling Send P-Asserted-Identity under Device profile and enable Trust ID Outbound alongside Trust ID Inbound under outbound trunk.
Hello, thank you, but it is still not working.
Here is what the device is sending to VitalPBX:
And here is what VitalPBX is sending to the trunk:
It seems like VitalPBX is not taking the PAI into account. Has anyone managed to successfully achieve what I’m trying to do?
Does this help you?
Hi mo10, I did see that post, but it doesn’t really apply to my use case. It seems overcomplicated for something so many people actually need. I’m not sure if this is a bug or just designed this way.
Why the Sofphone is not sending that information in the Caller ID headers. The Dynamic External CID only works when the caller sends a Caller ID value that needs to be pass to the destination.
We are using a few different PBX systems, and we can’t simply map or overwrite the From header using the PAI (P-Asserted-Identity) value because it causes authentication failures on outbound INVITE packets from the PBX side.
The softphone constructs its From header using its SIP authentication credentials—which is standard behavior, as a registered SIP client’s From header must match the AOR used for authentication—rather than the caller ID/display number you wish to present.
This is precisely why rewriting the outbound From header based on the PAI makes sense: if the softphone sends a valid identity via P-Asserted-Identity alongside its technical From header, that is the value the PBX should extract and use for outbound caller ID.
Unless I’m mistaken?
