I would like to know if there are any feature or addon in VitalPBX that record and analyse log’s from all users and extensions that has login with all detail about it, like (IP, port, …), some tool silimar like that:
GitHub - sipcapture/homer: HOMER - 100% Open-Source SIP / VoIP / RTC Packet Capture & Monitoring
We just see in the community version the log’s from calls and ative users, not any history from each login from users and details about it.
Thanks for your attention,
João Pedrosa
miguel
February 25, 2022, 1:04am
#2
Currently, the only way to get something similar is using the “SNGREP” tool in the Linux CLI.
Anyway, thanks for the suggestion. We will go over the possibility to integrate VitalPBX with Homer in the future.
Hi miguel.
Thanks. I think that is a good idea join the both tools graphical log from call with all steps and the join all logs.
PitzKey
February 25, 2022, 8:23am
#4
When you say ‘login’ are you referring to registration, or something else?
Also, you can easily integrate HOMER with Asterisk directly.
Hi PitzKey,
Yes, is the registration.
I don’t try not yet but yes I see this feature for Asterisk HEP/EEP Collector
Examples: Asterisk · sipcapture/homer Wiki · GitHub
PitzKey
February 25, 2022, 9:13am
#6
We use Kamailio as an Edge Proxy and have integrated HOMER with Kamailio. It is easier to integrate with Kamailio then Asterisk.
