Overriding Provisioning Files
What is the path to store custom provisioning files> With the old EPM, if we used to place a MAC.cfg file in the xepm directory and it would work just fine.
I see that there is a path /var/lib/asterisk/phoneprov, but it doesn’t seem to serve the files in that directory.
It should be:
/var/lib/vitalpbx/provisioning/provisioning_templates/PROVISIONING_URL_FOLDER/
