Odoo CRM integration
I think it would be great to have Odoo CRM integration to VITALPBX. ODOO has over 7million users worldwide
Odoo CRM & ERP has over 12 million. It’s my suggestion and on behalf of mt clients that you add it to the list of the current integration Salesforce, ZOHO etc
They went from 7m to 12m in just four months? Nice :wink:
Odoo is really growing, I strongly suggest you consider this integration. Thanks
I fully support the Odoo integration request.
As a VitalPBX reseller and integrator, I see strong demand for Odoo CRM & ERP integration from clients who already use this platform in their daily operations. Odoo has matured into one of the most flexible and widely adopted open-source business suites, and linking it with VitalPBX would open the door to advanced automation, call tracking, and seamless communication workflows directly within the CRM.
This would be a major step forward, especially given the existing integrations with Salesforce and Zoho.
Please consider adding Odoo to the official integration roadmap.
I have Integration to odoo 15,16,17,18
Can you send some details please?
What details do you want to know?
about your integration
Yes. How can I help?
VitalPBX already list ODOO as part of their CRM integrations.
Only partially. I have add-ons on the Odoo side.
It integrates only what it needs. As with Zoho and Salesforce!
I would like to report that the integration between VitalPBX and Odoo is only working partially. The main issue is that the system does not create the phonebook and it fails to synchronize the contacts. This limitation is preventing us from achieving the expected functionality, and we would appreciate guidance or a fix to ensure full integration.
Thank you in advance for your support.
I would like to follow up on my previous post regarding the integration between VitalPBX and Odoo. As mentioned, the system does not create the phonebook and fails to synchronize the contacts. Could you please let me know if there are any updates, workarounds, or planned fixes for this issue?
This limitation continues to affect our workflow, so any guidance or timeline for resolution would be greatly appreciated.
Thank you again for your support.
