Reading the dialplan, I see that there is a NoCDR in each and every queue I had created using the GUI, question is: Is there an specific reason why there is a NoCDR in line 16 of each queue? Do we know what is this for or if there is a reason for this to be set like that?
Hey!! thanks for your quick reply. Not only it is avoiding duplicate records, but it is skipping registering calls altogether for some calls.
When calls arrive and their route points to a queue, this record is simply not registered. Sometimes these calls get recorded in CDR, sometimes they don’t and I would like to find out more, I can see the calls logged in /var/log/asterisk/full, one other thing is that an inbound call will only get recorded if their final destination varies from a queue, meaning that if there is a condition that takes the call out of the queue, say for instance, a voicemail box, then there is a CDR record, otherwise, if the call terminates with an agent interaction from a queue, it will not leave a CDR record, Why?
That is exactly what still happening with me, not only calls directed to queues, but also IVR and announcements not recorded in the CDR too.
each call that reach the system or any destination should appear in the CDR report. if we are testing calls that comes to queue directly (with ring other than MOH) or IVR, we don’t know until we know that IVR welcome message.
For me, A call goes to time condition and if condition met during office hours, it should go to queue to ring members there (the case is there is no available (logged-in) members and the call last in the queue for some tile till the caller hangs up the calls) .
And if the condition not met, it will direct to an announcement ( to play out of office message) then hangs up the call.
