Incoming calls are working well, VitalPBX won’t place outbound calls, this is a multi-tenant server (not sure if this matters). I know I am missing something simple, but three hours of comparing the configuration of a functional VitalPBX isn’t finding the solution.
/var/log/messages is telling me:
Sep 28 13:41:03 phone101 asterisk: [][2022-09-28 13:41:03] #033[1;33mNOTICE#033[0m[1104][C-00000018]: #033[1;37mcore_local.c#033[0m:#033[1;37m737#033[0m #033[1;37mlocal_call#033[0m: No such extension/context 3143212222@T2-outbound while calling Local channel
grep -ris 3143212222 /var/log/asterisk/full
[2022-09-28 13:41:03] VERBOSE[1104][C-00000018] pbx.c: Executing [3143212222@T2_cos-all:1] NoOp(“PJSIP/101_105-0000001a”, “More than on digit pattern”) in new stack
[2022-09-28 13:41:03] VERBOSE[1104][C-00000018] pbx.c: Executing [3143212222@T2_cos-all:2] Gosub(“PJSIP/101_105-0000001a”, “s,1(3143212222)”) in new stack
[2022-09-28 13:41:03] VERBOSE[1104][C-00000018] pbx.c: Executing [s@T2_cos-all:1] Set(“PJSIP/101_105-0000001a”, “EXTENSION=3143212222”) in new stack
[2022-09-28 13:41:03] VERBOSE[1104][C-00000018] pbx.c: Executing [s@T2_cos-all:2] NoOp(“PJSIP/101_105-0000001a”, “Dialing 3143212222 from 105”) in new stack
[2022-09-28 13:41:03] VERBOSE[1104][C-00000018] pbx.c: Executing [s@T2_cos-all:3] Gosub(“PJSIP/101_105-0000001a”, “sub-set-global-vars,s,1(c14dd165f0929b75,3143212222,parking-2)”) in new stack
[2022-09-28 13:41:03] VERBOSE[1104][C-00000018] pbx.c: Executing [s@sub-set-global-vars:4] Set(“PJSIP/101_105-0000001a”, “__PICKUPMARK=T2_3143212222”) in new stack
[2022-09-28 13:41:03] VERBOSE[1104][C-00000018] pbx.c: Executing [s@T2_cos-all:4] Gosub(“PJSIP/101_105-0000001a”, “sub-set-call-vars,s,1(c14dd165f0929b75,3143212222,2,T2_cos-all,T2_ARS-all)”) in new stack
[2022-09-28 13:41:03] VERBOSE[1104][C-00000018] pbx.c: Executing [s@sub-set-call-vars:3] Set(“PJSIP/101_105-0000001a”, “_CALL_DESTINATION=3143212222”) in new stack
[2022-09-28 13:41:03] VERBOSE[1104][C-00000018] pbx.c: Executing [s@sub-set-call-vars:9] Set(“PJSIP/101_105-0000001a”, “CDR(destination)=3143212222”) in new stack
[2022-09-28 13:41:03] VERBOSE[1104][C-00000018] pbx.c: Executing [s@T2_cos-all:9] GotoIf(“PJSIP/101_105-0000001a”, “0?T2_emergency-calls,3143212222,1”) in new stack
[2022-09-28 13:41:03] VERBOSE[1104][C-00000018] pbx.c: Executing [s@T2_cos-all:16] Goto(“PJSIP/101_105-0000001a”, “T2_cos-all-post,3143212222,1”) in new stack
[2022-09-28 13:41:03] VERBOSE[1104][C-00000018] pbx_builtins.c: Goto (T2_cos-all-post,3143212222,1)
[2022-09-28 13:41:03] VERBOSE[1104][C-00000018] pbx.c: Executing [3143212222@T2_cos-all-post:1] NoOp(“PJSIP/101_105-0000001a”, “Outbound Route: BulkVS-Out”) in new stack
[2022-09-28 13:41:03] VERBOSE[1104][C-00000018] pbx.c: Executing [3143212222@T2_cos-all-post:2] Gosub(“PJSIP/101_105-0000001a”, “sub-setup-call-type,s,1(outgoing)”) in new stack
[2022-09-28 13:41:03] VERBOSE[1104][C-00000018] pbx.c: Executing [3143212222@T2_cos-all-post:3] Set(“PJSIP/101_105-0000001a”, “DNID=3143212222”) in new stack
[2022-09-28 13:41:03] VERBOSE[1104][C-00000018] pbx.c: Executing [3143212222@T2_cos-all-post:4] NoOp(“PJSIP/101_105-0000001a”, “Start to Dial Trunks”) in new stack
[2022-09-28 13:41:03] VERBOSE[1104][C-00000018] pbx.c: Executing [3143212222@T2_cos-all-post:5] Goto(“PJSIP/101_105-0000001a”, “s-1,1”) in new stack
[2022-09-28 13:41:03] VERBOSE[1104][C-00000018] pbx.c: Executing [s-1@T2_cos-all-post:5] Gosub(“PJSIP/101_105-0000001a”, “trk-2,3143212222,1(from-trk-grp)”) in new stack
[2022-09-28 13:41:03] VERBOSE[1104][C-00000018] pbx.c: Executing [3143212222@trk-2:1] Set(“PJSIP/101_105-0000001a”, “_NTD=3143212222”) in new stack
[2022-09-28 13:41:03] VERBOSE[1104][C-00000018] pbx.c: Executing [3143212222@trk-2:2] Gosub(“PJSIP/101_105-0000001a”, “trk-2-dial,3143212222,1(from-trk-grp)”) in new stack
[2022-09-28 13:41:03] VERBOSE[1104][C-00000018] pbx.c: Executing [3143212222@trk-2-dial:1] NoOp(“PJSIP/101_105-0000001a”, “Trunk: BulkVS”) in new stack
[2022-09-28 13:41:03] VERBOSE[1104][C-00000018] pbx.c: Executing [3143212222@trk-2-dial:2] NoOp(“PJSIP/101_105-0000001a”, “Dialing: 3143212222”) in new stack
[2022-09-28 13:41:03] VERBOSE[1104][C-00000018] pbx.c: Executing [3143212222@trk-2-dial:3] Set(“PJSIP/101_105-0000001a”, “CDR(trunk)=2”) in new stack
[2022-09-28 13:41:03] VERBOSE[1104][C-00000018] pbx.c: Executing [3143212222@trk-2-dial:4] Set(“PJSIP/101_105-0000001a”, “SKIP_HANGUP_AUDIOS=no”) in new stack
[2022-09-28 13:41:03] VERBOSE[1104][C-00000018] pbx.c: Executing [3143212222@trk-2-dial:5] Gosub(“PJSIP/101_105-0000001a”, “sub-setup-call-type,s,1(outgoing,no)”) in new stack
[2022-09-28 13:41:03] VERBOSE[1104][C-00000018] pbx.c: Executing [3143212222@trk-2-dial:6] ExecIf(“PJSIP/101_105-0000001a”, “0?Set(CALLERID(all)=):”) in new stack
[2022-09-28 13:41:03] VERBOSE[1104][C-00000018] pbx.c: Executing [3143212222@trk-2-dial:7] GotoIf(“PJSIP/101_105-0000001a”, “1?:after-val-sim-calls”) in new stack
[2022-09-28 13:41:03] VERBOSE[1104][C-00000018] pbx.c: Executing [3143212222@trk-2-dial:8] Set(“PJSIP/101_105-0000001a”, “MAX_TENANT_CALLS=0”) in new stack
[2022-09-28 13:41:03] VERBOSE[1104][C-00000018] pbx.c: Executing [3143212222@trk-2-dial:9] Set(“PJSIP/101_105-0000001a”, “TENANT_NAME=kat001_katycomputer”) in new stack
[2022-09-28 13:41:03] VERBOSE[1104][C-00000018] pbx.c: Executing [3143212222@trk-2-dial:10] GotoIf(“PJSIP/101_105-0000001a”, “0?:after-val-sim-calls”) in new stack
[2022-09-28 13:41:03] VERBOSE[1104][C-00000018] pbx_builtins.c: Goto (trk-2-dial,3143212222,18)
[2022-09-28 13:41:03] VERBOSE[1104][C-00000018] pbx.c: Executing [3143212222@trk-2-dial:18] NoOp(“PJSIP/101_105-0000001a”, “”) in new stack
[2022-09-28 13:41:03] VERBOSE[1104][C-00000018] pbx.c: Executing [3143212222@trk-2-dial:19] NoOp(“PJSIP/101_105-0000001a”, “Configuring Trunk Parameters”) in new stack
[2022-09-28 13:41:03] VERBOSE[1104][C-00000018] pbx.c: Executing [3143212222@trk-2-dial:20] ExecIf(“PJSIP/101_105-0000001a”, “1?Set(CHANNEL(musicclass)=default):”) in new stack
[2022-09-28 13:41:03] VERBOSE[1104][C-00000018] pbx.c: Executing [3143212222@trk-2-dial:21] Set(“PJSIP/101_105-0000001a”, “__TRUNK_MOH_SET=yes”) in new stack
[2022-09-28 13:41:03] VERBOSE[1104][C-00000018] pbx.c: Executing [3143212222@trk-2-dial:22] Set(“PJSIP/101_105-0000001a”, “DIAL_PREFIX=”) in new stack
[2022-09-28 13:41:03] VERBOSE[1104][C-00000018] pbx.c: Executing [3143212222@trk-2-dial:23] Set(“PJSIP/101_105-0000001a”, “_TRKDIALOPTIONS=ktr") in new stack
[2022-09-28 13:41:03] VERBOSE[1104][C-00000018] pbx.c: Executing [3143212222@trk-2-dial:24] Set(“PJSIP/101_105-0000001a”, “ORIGINATOR=105”) in new stack
[2022-09-28 13:41:03] VERBOSE[1104][C-00000018] pbx.c: Executing [3143212222@trk-2-dial:25] Set(“PJSIP/101_105-0000001a”, “RING_TIME=90”) in new stack
[2022-09-28 13:41:03] VERBOSE[1104][C-00000018] pbx.c: Executing [3143212222@trk-2-dial:26] Set(“PJSIP/101_105-0000001a”, “CALLED=3143212222”) in new stack
[2022-09-28 13:41:03] VERBOSE[1104][C-00000018] pbx.c: Executing [3143212222@trk-2-dial:27] Set(“PJSIP/101_105-0000001a”, "TRUNK_ENDPOINT=T2”) in new stack
[2022-09-28 13:41:03] VERBOSE[1104][C-00000018] pbx.c: Executing [3143212222@trk-2-dial:28] Set(“PJSIP/101_105-0000001a”, “__CALL_TYPE_CONFIGURED=no”) in new stack
[2022-09-28 13:41:03] VERBOSE[1104][C-00000018] pbx.c: Executing [3143212222@trk-2-dial:29] Dial(“PJSIP/101_105-0000001a”, “Local/3143212222@T2-outbound,90,ktrU(sub-before-bridging-call^c14dd165f0929b75^105^3143212222^)”) in new stack
[2022-09-28 13:41:03] NOTICE[1104][C-00000018] core_local.c: No such extension/context 3143212222@T2-outbound while calling Local channel
[2022-09-28 13:41:03] VERBOSE[1104][C-00000018] app_dial.c: Couldn’t call Local/3143212222@T2-outbound
[2022-09-28 13:41:03] VERBOSE[1104][C-00000018] pbx.c: Executing [3143212222@trk-2-dial:30] NoOp(“PJSIP/101_105-0000001a”, “After Dial”) in new stack
[2022-09-28 13:41:03] VERBOSE[1104][C-00000018] pbx.c: Executing [3143212222@trk-2-dial:31] GotoIf(“PJSIP/101_105-0000001a”, “1?come-back”) in new stack
[2022-09-28 13:41:03] VERBOSE[1104][C-00000018] pbx_builtins.c: Goto (trk-2-dial,3143212222,33)
[2022-09-28 13:41:03] VERBOSE[1104][C-00000018] pbx.c: Executing [3143212222@trk-2-dial:33] Return(“PJSIP/101_105-0000001a”, “”) in new stack
[2022-09-28 13:41:03] VERBOSE[1104][C-00000018] pbx.c: Executing [3143212222@trk-2:3] GotoIf(“PJSIP/101_105-0000001a”, “1?come-back”) in new stack
[2022-09-28 13:41:03] VERBOSE[1104][C-00000018] pbx_builtins.c: Goto (trk-2,3143212222,5)
[2022-09-28 13:41:03] VERBOSE[1104][C-00000018] pbx.c: Executing [3143212222@trk-2:5] Return(“PJSIP/101_105-0000001a”, “”) in new stack
[root@phone101 ~]#
