New TTS AI Feature - Save Text
Thank you for adding the ability to generate the greetings using OpenAI. This is super helpful.
If possible, please add that it should save the text string and the voice used, so if we need to modify it we can come back, edit and re-generate.
We will have it in mind!
This is now possible in the latest VitalPBX 4 update.
