I have found in the header that the vega 60g is sending the name in the P Header. Is there a way to tell the VitalPBX to look at the p header instead of the contact or from?
When I would set the from header to send the correct info all the calls would get rejected. After searching why calls would be getting rejected, I found a thread that mentioned the match setting in the trunk settings. After setting match to be the IP address of the Vega60g, I was able to receive calls again with full Caller ID
Well after setting match IP setting, it killed the trunk registration which killed outbound calls. I believe there is something with trying to set them up under PJSIP that doesn’t work. 2 totally different fxo gateways with similar issues.
